Thanks for that mep and DonH50. I asked my tech again about this issue. He seems pretty sure that the caps are good in my ARC and that in general caps are replaced far more often than they need to be.
I think that one of the problems in general about older equipment is that it is prone to failure due to any number of different issues based on age.(kind of like us too!) I suppose one could replace all the caps and tubes and possibly
even resistors and then expect a more robust life. OTOH, I have had tube amps that were fairly new and had caps blow and tubes arc etc. I think that this may be one of the problems with an amp or any piece
of equipment that gives off a lot of heat. I do agree totally with DonH50's last sentence though.
BTW, mep, surely the life of the cap has to do with the amount of time that the unit is up and running. Would not an amp that runs 24/7 typically have a lower life on the caps than one that has been used infrequently over many years?
You say elecrtolytic caps are spec'd for a 20 year life; surely that must somehow correspond to the amount of use that the amp has seen? ( the more use, the lower the life, the less use the longer the life) The type of climate and care that the amp has been used in also might have a bearing on the life of the parts.There are guitar amps on the market and being used right now, that are over 50+ years old that are still highly prized due to the fact that they have their original caps and basic parts/speakers etc, are you saying that all of these amps are likely to self-destruct due to their age? I am just wondering?
