IME, the current crop of Jadis amps that are the mk2 versions are in a different league than the earlier models.
Even so, it was the preferred Jadis of Gary Koh, when strapped in mono blocks.
Honestly, I think I would prefer the smaller room, LOL.![]()
that Alta speaker has some issues technically:
https://www.stereophile.com/content/alta-audio-hestia-titanium-loudspeaker-measurements
i'm curious if you concur with JA.
For me, personally, Lamm ML3 on high-sensitivity big Wilsons, SET NAT on Zu and Absolare SETs on Rockports proves this to my satisfaction. At least for my favorite types of music (vocals, simple acoustic accompaniment, jazz) SETs on high-sensitivity cones totally works for me.
Well you liked that KR integrated on the Acoustats too and I disagree the Sphinx was so much better. Plus KR is a reverse hybrid
Well, you have your strong opinions but I lived with both for several years and while the SPL limits of the Sphinx was higher it was definitely not better sounding. So what if the KR is a reverse hybrid? It is still SET.
On what brand and model of amplifier stand does Bob have each pair of JA200 Mk II amplifier and power supply sitting side-by-side on the same stand?
Critical Mass Systems Maxxum amp stands. http://www.criticalmasssystems.com/productPages/MAXXUM.html
Time for another visit Ron
I have to add that Ked was here on Friday- the AF1Premium/Graham Elite/Coralstone were set up 4 days prior to Ked's visit. The TT/arm/cartridge had <10 hours on them. Even since Ked's visit and another 50+ hours on the Coralstone for me has changed the overall sound dramatically. I would expect that by 100 hours it will a totally different sonic presentation. There is a weight and body to the AF1 vs AF3 that has started to surface that was not there when Ked visited last week.
The JP80II/JA200II's are also two weeks old with about 100 hours on them. You can't really tell anything yet. Give all of this about 500 hours and then you can understand what both the table/arm/cartridge/electronics are really about.
The AF3/Graham/Etna SL all are totally broken in. This AF3 is the one that MF recently reviewed in Stereophile and Analog Planet.
I usaully play the JA200II's in the 30% mode. It's about 50-60 Watts Class A. I can't tell much difference driving the M3's in the 30% mode or the full 170Watt mode at normal listening levels AND they run a LOT cooler than when in the full 170 Watt output mode.
I would also add that as much as I loved Ked's LP's/classical that he played, I pretty much play and listen to totally different types of music. Personally I'm much more into the music itself vs. how the system or something "sounds".
I listen to a lot of Leondard Cohen, Sharon Robinson, Sufjan Stevens, Michael Hedges, Patricia Barber, Beck, Duke Ellington, Miles D., Dead Combo, 60's/70's rock, Ben Webster, Rodney Crowell, Dean Martin. Classical is wonderful, I listen to classical occasionally but it is not my personal go to listening venue.
Out of the customers that visit (between 10-15 week normally) 90% of the them listen to jazz, current alternative, 60's 70's rock. About 10% ask to play classical.
Very interesting... do you think this holds across the board?
Bob, the Zesto valves can also be rolled. People are rolling them with Mullards and telefunken
