The wood panels and resonators are part of the Shun Mook concept you'll see it on their website but what's not visible in the pict are the two rare Mook racks on either side of the American Sound. They are incredible looking, probably the most beautiful racks I've seen.
I have my JL Audio F112v2 standing on ASC SubTraps. Without these and with the subs sitting on the floor the sound would be muddy; I know this from my previous sub. It depends of course on the floor you have. I have wood floor that shakes with bass.
With SubTraps I have clean, fast, resolved bass from the JL Audios.
In isolation sensitivity figures are just a starting point there are other factors including driver design that affect the sound and true sensitivity of the speaker. This pair has Kharma's F proprietary drivers which are incredibly fast and light, the largest woofers weigh about 3-4kg including the basket and magnet. I heard this speaker at CES 2017 in our room for the first time and was surprised how well they paired with the ML3, I haven't had them side by side but I'm pretty certain that they're easier to drive than the 96db Wilsons.
You mean that the subs cancel out the low bass from the main speakers? How would that muddy the sound? I would imagine that doubling of the bass would be more problematic in that respect.
I had the 91db efficient Kharma Exquisite Ref 1D's (likely almost the same situation as these Kharma's) in a similar sized room with 75 watt Tenor OTL's (likely similar in power to the ML3's) and they were very lively and energetic. it's a simple first order crossover and overall the sound was free, open and coherent.
OTOH those Tenor's did detonate a few times and take out the ceramic mid-range drivers. made for some excitement. but that's a less than completely sorted out OTL for you.
my point being that this combination does work in the right room.
What did I miss Al? In this room I find the subs canceling out the low bass from the main speakers and muddy mid & upper frequencies but owner likes using them now & then, they round off and warm up the mids.
Ok, but what does the canceling out of the low bass from the main speakers by the subs have to do with muddying up mid & upper frequencies?
BTW, rounding off and warming up mids by the subs? Not something that I'd want. I need maximum resolution. Fortunately, in my system the subs don't pose that problem.
The muddying up isn't caused by the bass cancellation but both are symptoms of the subs. I don't like the added warmth either but not my room and my friend enjoys it at times.
OTOH those Tenor's did detonate a few times and take out the ceramic mid-range drivers. made for some excitement. but that's a less than completely sorted out OTL for you..
As fond as I was of the Exquisites we both owned Mike these are a lot easier to drive much livelier and more dynamic speaker, they sound quite different too.
