In an abstract way,it can resemble the TriodeFet circuits of our Ianus amplifiers. However i would not go that far call it tube OTL amplifier
I interpret this to mean that the load (i.e., the loudspeaker) is seeing current delivered to it directly by the transistor power supply.
I think I would characterise this design as a "semi-hybrid" design in that the voltage side is tube driven with a tube output, and the current side is tube driven but with a solid-state output. I think this topology is somewhere between a hybrid amp (or a reverse hybrid amp) and an all-tube amp.
But if the current side is solid-state then is that why no output transformer is required? If so, can we consider this to be an OTL amplifier?
Would the real EEs please step up and solve this mystery for us?
A hybrid amplifier would use tubes as voltage gain,driving a SS output stage.
Ron, SS are "OTL" (well there are exceptions) but the term is not used for Solid state designs.They do not use OPT as it is not needed.
This design,though it is not wise to comment on other designer's work,does not work like usual hybrid designs.
In hybrid designs,the tube stage only delivers drive to the output stage and not to the load.
In this design,the 300B does deliver current to the load(although it is limited to it's max 50-70mA ) which only is enough for a few milliwats for a normal speaker.The SS section of the output stage ,"sample" the current of the 300B which drives the load,and "boosts" the current.Now,the SS section, does in a way,mimics the transfer curves of the tube,so the distortion and sonic footprint of the amp is leaning more towards the 300B not the SS.
We have experiment in this technology,and a (distant though) member of this technology is the Ianus.
Having designed and lived with many examples of similar tech,it is not a surprise if the Alieno does indeed sound like a tube amp and performs marvelously if.
Cheers
Stavros
I just spent about four hours using Google translate to translate from Italian to English dozens of posts about the Alieno 250 LTD amplifier on an Italian audio forum. The translated posts did not tell me anything.
But then I found this:
Would the electronic engineers here please get to work reading and understanding this description, and explaining the circuit design of the Alieno to the rest of us? Thank you!
IMHO, we are still playing with semantics. The controlled current source will have a sound signature, it is not an OTL in its usual sense used during decades. Probably an interesting design, I can not comment any more without too much guess - we would need technical details.
We had similar issues about the Berning ZOTL's - hundreds of posts debating if they were or not OTLs, the subject is not new.
Perhaps someone can design a tube amplifier block and couple it to the booster transistors using Peter Walker current dumping technique. Then he can call it an OTL! See https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=13&cad=rja&uact=8&ved=0ahUKEwivjPyA3v3YAhUGchQKHVIYAawQFghoMAw&url=http%3A%2F%2Fwww.keith-snook.info%2Fwireless-world-magazine%2FWireless-World-1978%2FCurrent%2520dumping%2520-%2520does%2520it%2520really%2520work%2520DCD.pdf&usg=AOvVaw0g8lMNEb1Sbiw6MaGmaxTQ )Current dumping—does it really work? Theory and practice by J. Vanderkooy and S. P. Lipshitz University of Waterloo, Ontario)
Unfortunately OTL is becoming a marketing key word - all these amplifers want to live on the tradition of great sounding true OTLs.
BTW, please remember that the Aries Cerat Collatio looks like a true OTL!
Please note, it is as far as I know, I can be wrong because information is very scarce and can not be confirmed.
The Collatio is a true, purebred OTL. There is absolutely no misunderstanding or question about that!![]()
Purebred OTL, but not OTL/OCL - the supreme class where the same blessed electrons that flow through the tubes flow through your speaker.
Futterman's also had a capacitor in the output, but were push pull type, not SE.
Hello micro.
The capacitor used at the exit is as transparent as a single wire (1mohm ! ESR) ,mind you this cap has with a max surge spec of 12.000A.Pretty much as single wire as can bewith a size to much..It presents much less internal resistance than the contact resistance of a good binding post
It can protect the user's valuable and fragile drivers flying through their grills in case of bad tube(i have seen this happening with an otl amplifier and a ceramic driver speaker,with fine ceramic particles flying through the grill).
Cheers
Stavros
Yes, I knew about it, but probably the tube electrons do not!
Although I think that what matters is sound quality, not the microfarads, we must remember that a 50 000 uF capacitor has an impedance around of 150 mhoms at 20 Hz. Can I ask what is the capacitance of your output capacitor?
We should consider than many audiophiles consider that the best sounding solid state Quad amplifier was the capacitor coupled 303, not the later DC coupled ones.
Very interesting. Did not see a mention of the output impedance in the specs...are the 6?19? connected as followers? How would a customer determine if this would work with a particular set of horns?
As for the cap coupling, it is a compromise, but then what isn't? Coil design and core material also appear super critical, perhaps close to the importance of an output transformer.
(...) The Collatio is close to this number.However it can be configured in voltage mode when in monoblock mode (about 1ohm output impedance). (...)
Thanks for the details. Do you use local feedback in the monoblocks?
