Any adopters here of this very unconventional but interesting headshell?
https://www.youtube.com/watch?v=ei7NjQ_7QxY
http://www.highendcity.com/swing-headshell/
Intrigue got the better of me (yet again) after discovering this by chance, so an order went in and on return from a trip overseas, it was waiting here for me. I didn't intend installing it just yet as my TT is not fully finished but the other night thought ok, let's just give it a go and spent a couple of hours swapping the Art 9 over and getting the set up spot on with my laser engraved protractor specific to my SAEC WE506/30. Prior I was using SAEC ULS-3x, sintered aluminium oxide which is exremely hard material and very very stiff. This is the top SAEC headshell. Though I have not used any other shell's on my arm, I do have access to several through friends but was always contenet with the ULS-3x, so just stayed with it.
Anyway, the improvent that the Nasotec is claiming is to 'reduce', not eliminate error, from a pivoting arm. There is plenty of technical info on their website about why and what they are aiming at with this. Does it make any difference? Yes, it does. After the first few notes on Tracy Chapmans wonderful debut LP, it was obvious that the claims are backed up with ability. Notes seem to just flow unconstrained, at ease, with what I had considered more background notes, ambience etc coming more to the fore, bass in particular has very good texture and clean decay which really fleshes out the sound. A dozen or more Lp's simply confirm this, and last night, my Antal Dorati-Decca DMM-Stravinsky Rite of Spring sounded better than I have heard before, anywhere, truly captivating from begining to end.
I'm interested if any of you have used this? I know Daytona 600 has, so perhaps add your thoughts?
