Ilya Itin, Debussy, Preludes Book 1, Wave Kinetics Records
ok, for the last 30 minutes I've been listening to this native Quad dsd (4xdsd) solo piano recording. you can also get it at 2xdsd and single dsd (and.....they also recorded a 1/2" 30ips tape master off the same mic feed too, 8 reels worth for 'later'). (...)
Mike, I'm seeing a fairly major "call" by you imminently.
It'll be quite something if you say the 3-box Select II is pretty much the equal of vinyl in all major respects.
Kudos to you if you're finally "crossing the rubicon".
were not a blanket statement, or 'call'....... they were only related to textural detail. and on the best digital that is what I'm hearing.what I'm hearing is game changing in depth of textural detail. this is as much like tape to my ears, as vinyl...
I actually don't have a great deal of time for Native Hi Rez or audiophile labels in general.
Just me, no criticism of those like you who love the stuff.
I find the choice of music lacking and the performances all a bit "just perfect".
I'm w Al M in that "all the music" is on 16/44 w the piece you mentioned as a bit of frippery.
It's one of the reasons I won't move to tape other than the cost.
I'd rather hear a Horowitz or Rattle conducted recording than something done to satisfy a small number of Hi Rez aficionados.
Sorry if that sounds like I'm pouring cold water in yr findings, but I'm sure I speak for many on these forums.
But truly great if these pieces now match vinyl.
Where I would love you to comment is if this levelling of the digital v analog terrain is equally reached on Golden Age classic recordings, so any number of 50s and 60s classical greats, Tommy by The Who, Miles' In A Silent Way, Zep on 45rpm, modern stuff like London Grammar, Porcupine Tree etc.
Now if you relay in the next few wks that these and many more staples from the past and currently really match analog when played on yr Msb, I'll really be beyond impressed.
You wonder if there would be any improvement if you use a piece like the Stromtank and use in in battery powered mode and not from the wall. Each step you are talking about is adding a little more but sounds like as a whole is making everything better. You never talked about Digital and tape in the same sentence but in the last post you did. This is saying a lot about the sound you are hearing. Remember when the new renderer comes out it could move up again and next software update can do it again. My guess the MSB and your turntable are now closer than ever. IS it to the point if no turntable is there for comparison, you would have no problem with full digital listen? To me your posts are hinting the differences are getting smaller and smaller.
We'll likey get to play with one of those Stromtanks after CEDIA, in a few weeks...
Rather than the Stromtank you might consider an industrial/medical battery based regenerator. You can get 20Amps of very clean power that's completely decoupled from the incoming line. I put a massive balanced transformer downstream of that which then feeds my gear.
Thanks for the report - I will download the Book 2. It will be a nice change from my usual Claudio Arrau version on Philips. Time for a younger pianist, Arrau recorded it in his late 70's. Do we also get the 2xdsd when we buy the 4xdsd version?
BTW, just noticed this recording was carried using the Pyramix / Horus system - the same system used in the Savall recording that changed my perspectives on digital!
Sure Mike, no criticism intended.
I've been at a handful of audiophile pressing/direct to disc demos, and find I struggle w the material played.
I believe it's a major reason why many have avoided moving to 15ips tape as well, other than cost, we're not all enamoured w audiophile label Native Hi Rez catalog.
But each to their own, if you MUST have it all, then you MUST...LOL
Dear Mr. Lavigne,
I have from time to time follow this thread and saw repeated questions asking whether your digital fronts now equal vinyl. Suppose it is equal to vinyl, could an equal-to-vinyl digital possibly has different flavors like for example when we change cartridges. Or do they all sound alike in an equal-to-vinyl way.
Thank you for keep posting your path on digital. With all resource and efforts you put in, I hope your digital sounds even better than your vinyl.
Kind regards,
Tang
1 + 1 Tripoint Thor se = sonically more than 2 Tripoint Thor se' s. Somehow these Thor se cables enhance eachothers performance. You will be in for a real audio treat once your second Tripoint Thor se cable has settled. Enjoy (and keep us posted).
Talked yesterday to Miguel about Irma: there is still hope that it will not hit Florida in full force.
I've been playing around with the Select II over the last week or so, trying to find the upper limits of what it can do.
a week ago I tried my short 1.25m 'zeel' BNC interconnect substituting for the 'uber' expensive Tara Labs GME w/HFX rca's......between the Select II and the dart pre. i'm using rca->BNC adapters on the ends to work with the RCA outputs on the Select II. and.....I liked it a little bit better, and that's eliminating the grounding advantage of the $31k list price Tara, and dealing with a less than optimized 75 ohm output of the RCA outputs. just that little bit more 'there' and immediate.
then I made the big jump, removing the dart pre and going direct from the Select II to the dart monos with the 8m Evolution Acoustics 'zeel' BNC's (with adapters). i liked this a lot......and listened this way for a week. went back and forth once. the 'direct' was a bit more open and spacious, with the dart pre in there was a bit more meat and tighter soundstage. half way through i realized i had forgot to move the Tripoint Thor SE Master Reference Grounding cable from the dart pre to the Select II when i went direct. this added quite a bit of dimensionality and coherence to the music when i used it on the Select II going direct.
i was on the fence on this move, so yesterday i asked my local friend jazdoc to come over and lend his ears to the question. his take was similar to mine, but his feeling was that the dart pre added something more essential than what it gave up when removed. his sonic compass and mine are not the same, so i was not surprised with his perspective. he felt that the additional high frequency energy (my term is more open) of going direct would get old after awhile.
then he had a suggestion which turned out to be the right answer. use the dart pre, but leave the Tripoint Thor SE Master Reference Grounding cable on the Select II instead of switching it to the dart pre. this took things to another level altogether. more dimensional, coherent, and greater ease. quite a profound step forward.
thank you jazdoc, you are my hero. i'm loving this step forward.
so today i knew what i had to do.......and called Miguel Alverez of Tripoint in South Florida (his mind was focused on Irma headed his way) and was lucky that he happened to have a 1 meter Thor SE Master Reference Grounding cable he could send me. it will be here tomorrow afternoon. both the dart pre and the Select II will be able to use the Thor SE MR level cable.
best wishes to Miguel and all those in Florida in the path of Irma.
next; i need to report back to MSB that we need to modify an RCA output module with the 50 ohm BNC's so i get 100% of the benefit of that approach......to fully synergize with the dart pre.
i will report what i hear with the new cable. but things are really sounding amazing.
Hello Mike,
Maybe when I mentioned to you a while ago to try connecting Tripoint to your Select II, you thought that I meant to connect it to your pre. I tried for fun connecting Tripoint to both JmF transport and the Acqua dac, the improvement in sound were probably the same as what you experienced but different in magnitude because my digitals are just kindergarten level. I also did try switching the Power cord that came with JMF (JMF top pc) to my Siltech Tripple Crown. The improvement was even bigger than using Tripoint. There was another Thai guy tried putting just one Tripple Crown to one of his DCS four stack, the result was also an OOH AHH kind of happy reaction.
Kind regards,
Tang
not messed with different power cords or such things but feel pretty good about my whole power grid. not sure I want to wade into the 'ultra-uber' power cord thing.
