Pre and power matching
jasbirnandra
280
30
933
Dear Friends I have a small confusion with matching Pre with Power of different brands I am using the Ypsilon Pre which has an output impedence of 150 ohms trying to match the Pre with monoblocks of Block audio czech republic which were on static display in munich having Input impedence of 20 K ohms balanced and 10 K ohms unbalanced.
Will this be a good match or should I go with the no brainer Ypsilon Aelius AMP
From my limited experience and knowledge, there is matching impedance...and there is matching overall. Rule of thumb for impedance matching is 10x, so at 150 ohms vs 10,000-20,000 ohms you should be fine with this Block Audio amp.
However, in terms of matching overall, there are a number of members here who have found that CJ Pre/Power, Lamm Pre/Power, etc are such remarkable combinations, that "eyes closed", combinations using the same designer are often an easy and fantastic way to go.
Lloyd,
The rule of thumb you refer is meaningless - but as 99% of the times the equipment people use follow it, people love it.
As far as I remember the Ypsilon Pre can be used in active and passive mode, something that makes the answer more delicate.
Lloyd,
Well, and there you go! Funny how information gets passed around and around...and around. thanks for the correction.
For me one absolute rule is to pay close attention to the voltage figures. To have your amplifier reach its full potential, the input sensitivity figure for the amp must be close to the preamplifier's Vout. This almost always assures best signal to noise ratio which in turn sounds like less strain/ greater ease. The gravy is wider dynamic range.
It's the opposite of impedance matching with almost all solid-state components. Any unit with an output impedance well below 500 Ohms will be happy connected to any unit with an input impedance of 10k or higher.
Does anyone know the Vout for AR Ref 40/10, and CJ Gat? Can't find it
For VTL 7.5 MkIII it's
Maximum Output Voltage <1% THD 30V into 10k? or above (10Hz – 200kHz +/-1dB)
10V into 600?
While for Mk1 it's 45v
Jack,
I think you must mix gain here, not just Vout. Thinks can´t be so simple as you are writing!
10V into 600?
What are you calling Vout? Measured under what conditions?
Exactly that - what was put as maximum output voltage in the specs. Is that not right?
Here's what the documentation for the REF 10 says:
"Rated Outputs: 2V RMS (1V RMS SE) into 200K ohm balanced load (maximum balanced output capability is 30VRMS at less than 0.5% THD at 1kHz). "
One of the cool things the REF 10 has going for it is adjustable gain, configurably by input. On certain systems, I found out that less gain is actually desirable, and will certainly help with compatibility. I don't recall if the REF 6 has such adjustment, but I'll look...
cheers,
alex
cheers,
alex
You mean 6 DB at RCA and 12 balanced?
No, you can actually set "-2dB" gain by INPUT.
For instance, you can choose to run your dCS DAC at 6V and lower the input gain on your REF 10 to -3dB.
Is this possible with Ref 40?
cheers,
alex
It is my point - you can´t compare the Vout's -VTL specifiec 1% THD at 10 kohm load , ARC .5% on 200kohm.
For the REF10 the most important specification is the rated output : 2V RMS (1V RMS SE) into 200K ohm balanced load - it will produce a power of 200W in a 8 ohm load with a 26db gain power amplifier.
And as far as I could understand the offset gain of the REF10 only affects the attenuator/display settings, not the gain block of the preamplifier. It is just an display added convenience. But I can be wrong, please check it!
When you consider that most amps have sufficient gain that a single volt of output is enough to drive the amp into clipping, Vout is not a real consideration for nearly all preamps. More important is gain and noise and impedance. If gain is too high, you will often have serious noise issues. If impedance output of the preamp is too high and the amp too low, you may have high frequency roll off and in some cases bass rolloff too. Finally, and perhaps most importantly, I have found that the Robustness and stability of the power supply seems to be of high importance, although on the surface the current drive of a preamp is not so obvious...but my experience says it is crucial.
Gain and noise are sometimes related because noise is intrinsic of active devices and once it gets amplified you can not get rid of it, as attenuators are usually placed before the gain stage of the preamplifier.
The robustness and stability of the power supply are not easy to qualify. How should we specify it? Using the weight? Using the regulation? Some manufacturers quote capacitance as if it was nirvana ...
BTW, just remembered that a few modern solid state amplifiers have low gain - around 18-20 dB.
