Phono config for Transfiguration Proteus Cartridge
luiscesar
39
Madrid. Spain
Hello everybody !
I am going to receive a s/h Dartzell preamp for test (to see if i will bought or not) with my 108B and W/Ps.
(Original owner did not use the internal phono, so it is in original configuration, no idea about this config.)
I would like to know which phono configuration should work best for a Transfiguration Proteus Cartridge. ( Record Player is an AMG ViellaV12+J12 arm)
Since I have to solder I have no idea which work best.
Could anyone help me?
Thanks a lot
Luis
Output voltage : 0.2mV (3.54cm/s, 1kHz)
Internal impedance : 1 ohm
Recommended loading : 10 ohms
Body : aluminium, resonance controlled
Cantilever : 0.3mm solid boron
Stylus : PA (3 x 30µm) solid diamond
Core/coils : Ultra grade 3S – µ metal square core with 5N silver coils
Magnet : neodymium – front & rear
Weight : 7.8g
Frequency response : 10Hz – 20kHz +1.5dB, 20kHz – 40kHz +2dB
Channel separation : 30dB (200Hz – 1kHz)
Channel balance : 0.5dB at 1kHz
Tracking ability : 70µm at tracking force 2.0g at 315Hz
Dynamic compliance : 13 x 10-6 cm/dyne
Recommend’ tracking force : 2.0 g
dcc
662
1,303
1,230
Continental Europe -
I have a Transfiguration Proteus on my Brinkmann Balance/SME V combo and I am very pleased with the Allnic H3000V phono stage. Before buying it, I compared it against several phono stages in the same price range and it was the one that was the quietest and the most musical (at least to my ears and in my setup).
luiscesar
39
Madrid. Spain
I actually using a ARC Reference 5 preamp + ARC REF Phono 2 as phono preamp, and I am going to compare the Dart phono card vs ARC RefPhono 2, but I would like to do with the Dart properly configured
4,704
As far as I remember the default factory load of the old NHB18 was 836 ohm - 5.1 kohm in parallel with 1 kohm. Perhaps you can try using this load and the 1kohm in the ARC Ref Phono. You can try listening to effect of using different loadings using the ARC before changing values in the Dart, that needs a soldering iron and is a very delicate work.
Some years ago I did the experience you are going to carry and preferred the ARC REF phono 2 to the DartZeel phono.
luiscesar
39
Madrid. Spain
Thank you Microstrip !
I've been playing the ARC Phono2 with different loads, there is almost no differences between loads with the Proteus Cartridge, 1000Ohm was very good on ARC, but in the end i tend to select the lower values, only noticed less fatigating with longer listening periods, 100Ohm or 200Ohms are preferably, I not sure if I will have the same results with the internal phono card of the Dart.
Regards
