Question on crossover simulation
ClarisysAudio
Manufacturer
Jun 26, 2016
227
579
333
42
Global
Hello Members,
i am trying to find a software which can simulate the crossover schematic.
I did check the values on the schematics in various calculators and they seem to check out.
From what i understand, they are two 1st order high pass filters in series + two 1st order low pass filters in series to create a real slope.
Q: Is this a bandpass filter or how do you call that?
Q: Are the crossover points at 0db or -6? (For example: 0db @ 48Hz ; -6db @96Hz)
Thanks for any help
Florian
Hi Florian,
Have you checked out LTSpice?
Hi YashN,
thanks for the tip!
I am getting there, altough i had to load a module for my Burr Brown OPA606KP.
You're on the right track.
Yes, but now i am hitting a wall. I cant simulate the high pass but maybe when i get some more free time.
I did set the source to 1V AC....
Looks like all of them all in band-pass configuration to me.
You could trying simplifying the Tweeter band-pass with just one low-pass and one high-pass and see if it works, then add the others.
Keep at it, you should reach your goals.
Hi YashN,
thanks, i got it to work :)
Fully 4 Way
Final with no phase.
Well done!
