steve williams
I was using an A95 cartridge which has only 0.20v output. So I had to go up to 0.0db or higher to achieve over 80db. That is unnerving for me. I could see myself accidentally switching to my digital input and forgetting to adjust the volume.
But the real reason was the sound. I started playing some classical LP I was familiar with and noted that the quality of sound was very good, but then I got to a passage with strings in the upper octaves and couldn't hear it. Puzzled, I played a few other test LPs and noticed other elements of the arrangements very subdued. I then played LPs with vocals and found female voices slightly muffled. At this point I checked for loading options on the LP2.1 and found none, so switched back to my Pass phono to make sure my ears weren't blocked. Nope, ears were fine, lots of extension and clarity with the Pass. Then I got my wife to listen and she confirmed what I was hearing.
So... the question is why was this happening? I have no idea. I'm pretty sure nobody would design it to sound this way. Cartridge choice? I doubt that since I've heard Vladimir likes Ortofon. Maybe my RCA interconnect between the Lamm and my preamp (I normally use XLRs everywhere so had to settle for what I had on hand...).
I remain puzzled.
I will say that this unit is built like a tank and is extremely heavy (in a good way) and super silent. I had to put my ear practically ON my tweeter to hear anything, even with the volume turn high. Very impressive. As was the midrange texture and overall quality of the sound. It just didn't work out for me.
I recall 10 years ago (2001-2005) when I had the original Lamm LP2; which I used for 4 years as my reference. I liked it a lot.
however; it did not have the needed 'headroom' of gain to allow me to use some desired cartridges. it seemed like I was always pushing it to the limits. when used in it's designed performance envelope it was fine. it needed a cartridge with about .40v -.50v of gain to have enough headroom for the music to breathe. .30v was on the edge....
I had forgotten about that aspect of it.
It is more than puzzling because I know that Vladimir uses an Ortofon A95 as his reference. Christian IIRC who has the same Pass pre and amps was using reasonably low output carts and had no problems. Not sure if you know that there is a higher output version of the LP 2.1 (Mike I would suggest that 10 years ago you had the same and hence the newer higher output version) and in the LP1 Sig you get your choice of 2 SUT's in MC1 and MC2 and in the MM input you can use your own SUT's. Both my cartridges are low out put and hence my choice for two similar SUT's. I have never had that problem Ian so it is puzzling
