Personally I only used balanced, and I like to keep the length between the pre and amps under 4 inches.
And of course Furutech silver solder is used for the connections between pre and amps.
Thx a bunch Mike.
WBF was founded by two very different people with respect to audio. It has been that way from day one. But that is the state of Steve and I, not the forum. The rest of you are different and your posts reflect the state of WBF, over which we apply no censorship or control.I think this thread might represent the state of WBF. If one member says he hears no noise in his system, another member will argue on a public forum with him that there must be noise because of some calculations he just made. And these guys are supposed to be friends and co founders/partners.
I heard his system in his old house.Amir, have you heard Steve's system?
I was not there to analyze his system. I sat in a chair and he played a few clips for me and then I had to run.If so, and if you did not hear any noise from it, is it possible that it is because it has a very low noise floor or is it because you can not hear it with your just admitted compromised hearing?
I have no calculation for Steve's system. I presented the way one measures it and there was no interest. So we are left wondering if his system is noisy and he can't hear it, or that other way around. The data says given his cable lengths, the former possibility is quite real. His age also says that his ability to hear noise is diminished. That again emphasizes the former theory. We can settle this easily as we can measure noise but he is unwilling.Would there be a conflict because your calculations tell you something exists though you and others can not hear it?
There you goWhy is "hog wash" always a bad thing? I would think keeping one's hogs clean would be a positive.![]()
For matters related to sound reproduction in a room, yes. The moment you go before the signal reaches the loudspeaker, then two ear part almost disappears but the brain impact remains.BTW: Thanks for the link to the article. Is this quote something you concur with? “two ears and a brain are much more analytical than a microphone and a meter!”
Regards
Bob
BTW, download an SPL app to your phone and tell me if you see 0 dB SPL on it in your listening room. 0 dB SPL is still audible but for grins, go ahead and report back what you see.
Balanced XLR connections:
? This line is exactly four (4") inches long (on my own screen): ____________________
Mike, if an amp (monoblock) is positioned near its respective loudspeaker, and that the preamp sits between the two speakers...then normally (average) the balanced XLR interconnect from each amp to the pre would be roughly four feet long. ...And the speaker wire about two feet long?
The length of the wire from the AC plate to the main junction box in a home, is on average (mansion) between ten and hundred and fifty-five feet long.
And from the main junction box to the nearest street transformer is between roughly fifty and nine hundred and seventy-seven feet long, give it few feet longer or less.
Now, the street electrical wire is made of copper; would it be possible to replace it with silver wire?
Last: From the street's transformer to the town central electrical supply (main grid), the distance can be well in excess of forty miles. ...Say between twenty and hundred and sixty miles. And those wires are still made of copper. The gauge is what...9AWG?
I would have thought your range completely normal, similar here, fairly quiet residential street.Way ahead of you Amir. Jim Smith measured this a couple of years ago when he was here. And I just remeasured now. I first tried my digital Radio Shack meter, but it does not go below 60dB. It just reads "low". So I tried the "SoundMeter" app on my iPhone and just got a reading of 27 dB (A weighted) and 29 dB (C weighted) between wind gusts at my listening position. There is currently a winter storm, so it is very windy. It peaks at about 36 dB during loud gusts. At night, when listening, I have measured 25 dB. The house was built in 1795 and my listening room is on the first floor near a street corner, though there is not much traffic. Being in the historic district, I can not install insulated double pane windows, so I have only historically correct single pane true divided 6/6 sashes. I did replace the glass with laminated glass to cut some of the noise when restoring the windows. I'm sure other rooms are much quieter.
Additional information is that at normal listening levels I do not hear any noise out of my speakers from the listening seat. At 1" from tweeter or mid range driver, the noise level is 29 dB (A) and 31 (C) at normal listening volume, so about a 2 dB gain when the system is powered on relative to system off. If I turn the volume to max, I can hear 37 dB (A) and 40 (C) noise 1" in front of the tweeter and midrange drivers, but I can not listen at this volume as it is way too loud.
I've never heard of a room approaching 0dB SPL. What is the measurement of your room? And do you know what the noise floor measurement is for the typical listening room?
Yes this is very weird. Suggesting a plainly superior quieter method of interconnection, and people really get their hackles up about it. I am trying to think of any other area in high end audio that people opt for the inferior method and defend it. Sometimes in other areas equipment is quite adequate, but high end companies and customers insist on at least a little bit of overkill just to be sure. Yet in this one instance the definite better method is decried, the other method defended as not a problem. In this case good enough is good enough and don't bother with going beyond it. And only in this one case best I can remember. I wonder why that is?
I don't disagree with a word you said but do you also wonder why it is that reputable manufacturers have not and never will use balanced connections on their products and that one manufacturer would have given me a money back guaranty on his product if their was noise in the system from his gear. So please I for one don't disagree. All I am saying is their is no detectable noise for me with a 10M run and it is not age related so let's not introduce other deflecting arguments to what I said. BTW the system Amir heard in my room in Northern California used a 12 meter run and there was no noise. If it were there he would have heard it. There was none.
I used balanced cables throughout all but the last 12 years of my almost 50 in the hobby when I went with the manufacturer I continue to use now. It was the very first question I asked of the manufacturer because balanced cable throughout my systems past was always the way it was. I posted his comments here and I have had no issues so once again have you ever wondered why that is?
Umm, no. It's not weird at all. Some don't believe the increased complexity and cost of a fully balanced system is worth it in a typical home system. Not sure why that's so hard to understand, as it happens to be the case that many, many people use single ended systems without noise issues.
Maybe I think it's weird you'd want to opt for a more complicated, expensive way of doing things that offers no benefits whatsoever to 99.9% of people with normal home systems?
