Hi John,
I have some wands without any finger lifts. All I do is use the arm lift. To cue I keep the arm lift up and just gently slide the arm inwards and over the section I want to listen to then lower the arm lift slowly. To remove, I just up the lift and slide towards the locking mechanism. It takes a little bit of getting used and by little I do mean little. You should get the hang of it by at least the 5th try. 2 to 3 is more like it.
Enjoy the new deck!![]()
I picked up the EAT (European Audio Team) E-Flat late last year. What a superb table this is and a huge step up from the Michell TecnoDec/Arm that I had used for the last 5 years.
The flat arm being made of carbon fiber is extraordinarily rigid and seems to be completely resonant free. I have never owned a Uni-Pivot arm before, but this one seems extremely stable and well behaved. Much more natural in application than some of the VPI arms I've seen. The build quality of the table is outstanding. Precision engineered all the way around. I'm using the same Denon DL-304 that I had on the TecnoArm, so I get a very good sense of how different both tables really sound and perform.
My table came with serial number 131. Nice to finally own a great turntable that is not in the "mass produced" category. Couldn't be happier right about now.![]()
I just acquired a second hand Kuzma 4-Point and placed an order for a rear mount board for my AF1. Question now is, which cart do I mount on it?Decisions, decisions!
There is a new AirTight PC-1 Opus Magnum. I have not heard much about it yet other than the $15,000 price.
I'm really happy for you Fred! I love the look of that tonearm...it's so different and unconventional looking. Is there a tube underneath to hold the wiring?
That would be the GAE my friend and from what I've seen the goodies are in the innards. Still a huge jump from the M5G price wise to the GAE. HUGE! On paper however a core less DD motor? That is definitely something.
The new platter looks very interesting too. The platter was always a rather weak point of the 1200s. They rang like bells. This new one looks much more solid. I would love to get a chance to A/B the 5G with the GAE. I have identical carts for them. I also like that the IC is no longer captive. That was also something that was a problem. They had a tendency of getting yanked and you'd have to open her up to fix her.
