Having those speakers mounted on the ceiling like that must create a new set of room tuning challenges!
Lee
Lee
You mean where they are sitting right now? I think he is just storing them there.Now, this is what I am talking about....look at this set up and then compare to Michael's. I know which I would rather hear...and by a country mile!!!
That is supposed to be their claim to fame. And at any rate, he doesn't have the option of pulling the loudspeakers further out given the small dimensions of his room.I'm talking about the room set up in general. The Kiis are placed right up against the wall.
They are designed to be used there, or in a corner , or in free space, they have filters for the various placement options.
Keith.
Historically speakers we're designed for a specific function and placement, corner horns for example or the Ls3/5a.
Speakers are pulled away from walls , so that the bass which has been radiated against the rear wall will be cancelled at certain frequencies.
The Kiis are designed to be placed anywhere, and their frequency response canbe adjusted according to their placement.
For example if you placed them in a corner theirbass would be receiving significant reinforcement from the room.
The result is that you can place them anywhere in the room and still enjoy first rate sound quality.
Keith.
Speaker positioning is always a tradeoff when dealing with just 2 speakers in the typical rectangular room. The typical tradeoff goes like this:
1. Better bass when the speakers are closer to the frontwall (wall facing the listener)
2. Better 3D imaging as the speakers come off the frontwall and into the room.
If one only has 2 speakers, it's always a compromise of one over the other, IME. However, if one has the ability to bring some subs to the party, one can get the speakers out into the room AND have really great bass. Of course, these are my experiences, in my room. YMMV.
Dallas, Congrats!!!!
How's the sound now? Are you still tweaking?
Any desire to get CAT amps along with your Molas? At Axpona, that combo had that "to-die for" tube midrange with SS type bass.
Vivid speakers like toe in for sure. I have the tweeters pointed directly at the seated position. I've never been able to toe a speaker in this much without collapsing the soundstage. I previously had them about 1/2" toe in measured from sidewall. That's as much as I could toe in the YG Anat III without losing the big soundstage. I have the G3 at 3.5" toe in now. That's a lot more toe in. All other dimensions are the same.
The soundstage is just as wide as before. The midbass measures a little smoother and the HF is better integrated. Everything sounds much more resolving and sweet.
Wow Michael. You sure have a lot of surface material there. Do you have RT60 measurements of the room? I expect it to be on the low side.
Thanks. RT60 of 0.25 is very much on the low side. It is what I expect to see in multi-channel home theater setups. It is a pretty dry setup. But if you like it, you like it.
If by "small" you mean RT60 is not valid, that is folklore that is created on the web. It is not correct. See this rather long series of posts/articles I have written on the topic: http://www.whatsbestforum.com/showt...nt-thereof-to-quot-small-acoustic-spaces-quotAmir,
RT60 won't tell you very much in small rooms in absolute terms.
As I said, as long as you are happy, that is fine. Just wanted to note it as chasing low frequency absorption often results in rooms that are overly dead.Also, music preferences factor into the equation too. I listen to a fair amount of rock, pop, punk, dance and even some metal. Those genres don't sound great in a room with long decay, IME. I think all kinds of music sound great.![]()
I just finished reading the entire thread; I feel much better now. :b
I also read few reviews of both the G1 and the G3; impressive.
Here's one from Stereophile on your speakers Michael: http://www.stereophile.com/content/vivid-audio-giya-g3-loudspeaker#cczGyW2bY6O5Oe5J.97
That's not a very in depth review. I'm curious how the speaker handles the range of 100-350 hz in room at the listening position. It's quite rare to run side firing woofers up that high.
However the KEF blade runs them up to 350hz:
http://www.stereophile.com/content/kef-blade-two-loudspeaker#Ugr2yJlJlfEdUAei.97
