Auditioned the X-150.5 and the X-250.5
Ended up with the X-250.5
Just works better in my system ......
What type of system do you have?
I just happened to get a chance to go from XA200.5 to XA200.8!
After initial run-in this surely is a fantastic upgrade.
Just got a XP10......
What a difference....in a good way
What a difference....in a good way ??
What did the XP10 replace?
I wasn't using a pre, PSA Direct Stream to X250.8
The XP10 yielded much better bass, wider stage, a little less detail though .
