Thank you for the quantification Adam, For my part, DSD 256 only, balanced BiG 7 or GG would seem to be the most interesting path of consideration.
I would do the GG and have the best of both worlds
I have a balanced GG 256 DSD only on order.
Balanced with volume, black, DSD only (and USB input only). I have also asked for Apple TV remote option, like the one I had on my Big 7 (much better than the generic, plastic one ?ukasz is providing).
That will be my 3rd Lampi in 8 months time !
I have just hooked up a new GG, DSD256, PCM, balanced, RCA, XLR and volume control. We are starting off using it as a replacement for our reference preamp to judge its preamp capability. Later, we will use a dCS Puccini as a digital source and then use a Core Technology modified MacMini to test the USB, DSD, Hirez capabilities.
Initial reaction is very favorable as a preamp but obviously it will need some burn in before we get serious about evaluating its performance.
I think it has already been said but the remote operation is very awkward and could use some development work. But you have to take into consideration that they are a small company with a big to do list. The user manual needs a lot of work also. It is way too tweak oriented and needs to be more clear about installation and operation. But the GG itself is a beautiful work of audio art.
Caelin, if it's a balanced GG, how does it have RCA outputs?
Looking forward to hearing your thoughts as you get to know it.
Hi Ian,
I believe the balanced Big 7 and GG come with both XLR and RCA outputs standard.
Best,
Ken
Ian, I thought you had washed your hands of Lampizator. Second thoughts...![]()
Perhaps but I find that confusing given RCA is not balanced...
Congrats Caelin! That sounds like quite a component you just received. How are you liking your Core Technology modified Mac Mini? Do you hear a noticeable difference with this upgrade? I love the flexibility of my Mac Mini as I can load any software I want (i.e. Audirvana, JRiver & HQPlayer) and stream whatever I want (Internet Radio, YouTube, Tidal, etc.). I just wish I could close the performance gap between my Mac Mini and the Aurender servers for example.
Ken
I had a similar experience using a stock MacMini compared to a Lumin music server. I used the MacMini with several different DACs but the Lumin with its internal DAC outperformed the MacMini / DAC combination. Part of the performance difference could be that the Mac needs a USB cable to DAC connection and the USB cable affects performance. I think the Ethernet connection with the Lumin may be inherently superior.
I am currently using Roon with an HP touchscreen computer, iMac client and Core Audio MacMini client. I need to spend a lot more time with this setup but so far it is working out well and may be the best solution that I have found for Hirez music.
Caelin
How is the touch screen computer used
Adam,
Is it all black or just the front plate ?
