S sub
Tand
65
5
313
Norway
Looks like a new range of subwoofers from Magico. The S sub?
Yep, looks like an S (you can see screws on the front panel). I assume you can't on your QSub 15, tand?
Btw, you happy with that sub?
Thanks for posting...look forward to learning more.
Thanks, Wizard!
Correct :) No visible screws here!
I love the sub, it integreats perfectly with the Q3, I can hardly hear its on but when its off, I notice it easily! I use a center placement and this gives a more linear bass with defintion and thunderous bass when needed!
Tommy
Tommy
Never thought I would say this ...but this Magico (sub) looks awful :-(
Looks great to me too.
Too many visible screws on the front. Just a pity, that's all. But it will do the job excellently because it is Magico ;-)
I like it to! What do you think, is it 2x 10" or bigger? Would love too see 2x15" or 2x18" S Sub! :D
Looks awesome to me, I just hope it is not crazy money. Will go very well with my S5 :)
But you will need to buy one for each S5, and I guess an amp for each sub. :)
It looks like a IEC 20 amp connection on the back, so it should be active.
Must have been sleepy...bigger pictures on the site show my mistake: it looks fine :D
