Review now online:
http://www.stereophile.com/content/bricasti-design-m28-monoblock-power-amplifier
Also....
See attached....
Thanks. Here's an enlarged copy of that image, albeit blurry:
Review now online:
Also....
See attached....
@ skolis, #39 -- thanks for posting the response from the manufacturer.
I am just speculating here
but having just reread the review
I don't think he panned the amp just not the same as the two he compared with
But I also wonder as MF did what it would sound like with the boulder or true balanced preamp
My memory is that JA was not overly impressed with the dartzeel balance connection and the dartzeel sounds better with 50ohm connection
Was he hearing an impedance mismatch issue between amp and preamp?
My 2 ozzie cents
Interesting point, since when Brian runs his M28 amps at audio shows where the sound has been universally praised he drives it directly from the M1 DAC which is a fully balanced design. He also makes a point of mentioning that in that configuration it is running true differentially balanced electronics from the source to the speakers.
Yeah, at AXPONA, it was Brian's laptop to the M1 to the M28s, to the speakers.
So, I'm thinking - laptop..... really??? and no preamp... really ???
And it's fully balanced 'cuz M1 is dual mono, and the sound is incredible...... (imho)
Also the Aurender W20 to the M1.
Yeah, they were running that too, which caught my attention 'cuz I'm so "over" having to "baby" my mac, the software, etc, etc, etc.
With the aurender - just "load and go".
When Stereophile posts a review they should also post any manufacturer comments as well. Not doing so is a disservice to the manufacturer as well as the reader.
You know I have had my eye on these amps since they were first introduced. I think the industrial design is outstanding
But text book measured performance? They can't drive a 2 ohm load! That's a deal breaker for $30k amplification......
You said "text book", Atkinson said "reveals". There are no specific references to the M28's measurements in what you quote. Its obvious Atkinson worded it to be polite here.
If an amp can't be measured into a 2ohm load it can't drive a 2ohm load. Period. There are plenty of amps that will work with spks that dip below 2ohms. That doesn't mean they can drive a 2ohm load
Kingsrule, I don't understand why you keep asserting this, because the M28s drove Fremer's Wilson MAXX 3's very well, and as another example Fidelis, a Bricasti dealer in NH, drives Wilson Sashas with them to great effect, as loud as one could possibly want. The fact of the matter is the M28 will drive practically any real world speaker load without limitations. But don't take my word for it: please go and actually listen to them.
