Years ago when Fourier went out of business, we accepted a pair from a customer with the idea that we would see if the amps could be repaired, since they were OTLs. <elided>
Fulton?
That was the death of my Maggies. Hit one just right when I was looking at something and it fell flat on its face, causing a rush of air to bust through the mylar. Luckily they were just SMGa's, but aggravating nonetheless.
I used to have Magnepan 3.6 loudspeakers and drove them with Wolcott P220 mono amps. Every time I powered them up, I would cross my fingers hoping they wouldn't detonate.
While the amp was on the bench, one of the filter capacitors blew itself off of the circuit board and embedded itself in the ceiling tile. I am so glad I was not peering over the amp when that happened! As it was, my ears were ringing from the explosion for a good 15 minutes.
DSC_0420 by andromeda61, on FlickrI once have destroyed a ls tweeter when i drove it too hard for its use and the other diamond cone while swapping preamp cables with the poweramp on, which it couldnt handle whatever happened ? , and yes those cost high $$$ one more reason not to use it in the future model, a loudspeaker should be able to take some abusebesides that i never had a ls unit break during play
Talking about destruction, how bout the saying curiosity killed the cat?
I have always bought tubes from very reliable sources overseas since the 90s and I never owned a tube tester since I believed my sources were better trained and equipped in testing tubes. In the mid 2000s, a neighbor bought a tube tester and in my curiosity to find our the state of health of my tubes, I asked to loan it for a few hours. While testing them, I took out my prized Telefunken ECC82 on my line stage and tested it, found it to be still in its strong stage, and when I tried to put it back, trying to feel the pins into the socket in the darkness of the rack shelf, I saw a spark in the tube socket area, and I thought immediately that I had fried the tube. Apparently, there was still some voltage left after I shut off the preamp and twisting the tube to insert the pins into the socket shorted it. A very painful experience for me for it was all about curiosity and nothing else. I now wait for 5 minutes at least after preamp shut down before reinserting a tube.
