The Noise Floor
GaryProtein
2,542
36
385
NY
What exactly is "the noise floor" and what contributes to it?
Noise floor is the minimum signal randomly (or pseudo-randomly) generated by the specific component or system in question. For an amplifier is hiss and noise. For digital audio, it is quantization noise (generated by the fixed minimum sample value).
Note that we "hear through" the noise so the noise floor does NOT set the lowest audible level of signals.
People with a isolated listening room so no out side noise is coming in have the advantage .
Regarding inside produced noise apart from the attendants , i d say source noise / amp noise tubes in particular and speakers to a lesser degree , imo a speaker which doesnt resonate will have a lower noise floor (blacker background ) as the unit membrane is not set in motion by the housing itself
A real nice listening room might have a 20 dB SPL background noise level.
But most rooms have a 30 dB or high SPL background noise level.
Classical music recorded in a concert hall is lucky if it's much under 30 dB SPL.
I believe Amir covered background room noise nicely in his article here
Absent the usual suspects (tube noise, ground hum loop, etc) what's ironic about this phenomena is you don't realize the "base level" noise floor in your system until you add / change something that allows you to hear the reduction.
you are right on
Exactly!! How many have heard the effect of a ground loop on digital audio - not a hum or buzz from the speakers - it throws a veil over the music, reducing dynamics & taking some of the "life" out of the music. This is not normally noticed until it is removed.
What weight?
