First, the Benchmark article says nothing specific about LP; only that "It can be shown mathematically that a properly-dithered digital system has the same resolution as an analog system having the same signal to noise ratio".
More importantly, there are misleading claims such as this:
Notice the fallacy: they claim hearing 30dB into the noise "around us", then they add that to CD's practical noise floor (according to them) of -93dB; as if the "noise around us" is as low as -93dB. Nope.
Therefore, I request credible references to: a) research confirming us hearing 30dB into the noise AT ANY noise threshold (clearly impossible, thus obviously a silly over-simplification in the claim); b) mathematical proof that a 16-bit system can encode signals below its theoretical best noise threshold of -96dB (or even -93dB) so that we can possibly hear into that noise threshold. Either way, 123dB claim is just baseless. Or if you think the theoretical best noise floor in 16-bit systems is below -96dB, let's prove that (see below).
Related to question (b), the article claims this:
Three problems: 1) the underlined is unsubstantiated - can we prove it mathematically? 2) by pushing noise up in the 18-22kHz range with noise-shaping (e.g. UV22), they conveniently ignore that region as part of the audible range over which dynamic range is calculated - flat-out wrong; the audible range now becomes the *conveniently-squeezed* audible range 3) they make it sound like a free lunch, but higher noise in that region will inevitably affect the high frequencies in the music - and the highs in RBCD is something we have always complained about.
So far, no one has proven that CD's dynamic range is higher than the LP's either.
Although you need to state this as noise shaped dither and then one needs to consider its implications that has been touched upon in the past in the engineering world by such as Bruno Putzeys; it is not a free lunch and can have further implications further down the processing-function chain as well.Yes you can record and listen to a tone recorded at lower than -96 db with dithered 16 bit. You will have to boost the level up until the tone and the noise are audible. While it is available we don't need mathematical proof as we can construct a signal and hear it ourselves......
Cheers
Orb
And you normally do not use shaped dither with PCM ADC audio or mixing (in context of this thread).Well no, just referring to the quote of me in your post. You can do this with flat dither and recover audible tones below -96 db. You can recover them lower if you shape the dither. Yes of course if you add noise and then process it with EQ or compression or other editing tricks downstream it can become audible. But the same would be true of post processing of LP noise or tape noise.
We did cover this earlier in the thread- in that it was agreed that 10db into the noise floor is possible. Given that it was not that hard to get to 100db dynamic range on an LP. Apparently, that 10db figure (or 20, or 30, depending on how much kool aid was drunk) won't work unless the noise floor truly is noise like white noise. If it is composed of harmonic and inharmonic distortions, the ear apparently cannot penetrate the noise floor.
The bottom line though apparently remains the same and and functions in the face of the limits of the technology: LPs will continue to have greater dynamic range in practice due to the practices of the recording industry.
Tomelex, I recommend you spend some time around an LP mastering machine, and compare your experiences with the same recording held in the digital domain. You might want to rethink your assertions as seen in post 237. In a nutshell I get the impression that you've not spent much time with state of the art LP playback. Another way to look at this: If it is distortion that people prefer about the LP, what does that say about human hearing? I am going to flip that around for a moment, maybe the answer will become clearer: if people don't like the small distortions of digital, what does that say about human hearing?
The answer is of course that some distortions are much more objectionable to the ear than others, even though our instruments record them at lower levels.
If we really want to create state of the art, IMO/IME we need to know how the human hearing/perceptual rules work, such that we make technology that conforms more closely to the things that the ear cares about rather than those things that look convenient and nice on paper. In this regard I am not saying LP is better ultimately (although I am saying it is better now); I am saying that if you want **any** recorded media to really shine, it has to pay attention to how our ear/brain system really works.
... The bottom line though apparently remains the same and and functions in the face of the limits of the technology: LPs will continue to have greater dynamic range in practice due to the practices of the recording industry. ...
Partially I agree, but not when it comes to classical music on digital. There engineers usually try to take advantage of available dynamic range (a few exceptions here and there notwithstanding).
And just a note, I don't agree with, "Given that it was not that hard to get to 100db dynamic range on an LP."
You might be misinterpreting the comment. I was simply adding up numbers (which was 'not that hard'), some of them presented by others here; at any rate actually getting 100 db on an actual LP in practice would be pretty challenging. You would have to have all the stars perfectly aligned to get the noise floor right.
The only way I know to do it would be direct-to-disc, but the noise floor of the room itself would probably mean that such a thing is practically impossible so it would have to be an electronic music recording. Same for digital as far as that goes.
I think what is confounding about all this is the generic use of noise. Noise can be white, pink, shaped or other shapes. How do you measure it? You specify an RMS level over a given bandwidth. I actually constructed a shaped noise through which I was able to hear a tone 50 db below the level of noise over the 20-20khz band. That was by having the noise low in the region of the tone and much higher elsewhere. You will see academic research when referring to white or pink noise say humans can hear 15 to 20 db into noise. With other shapes of noise a bit more is possible. So just using the term noise can be confounding if it isn't specified in this context of digital audio.
I imagine John at Benchmark had in mind -140 db for properly dithered tone in the 3-4 khz region with shaped dither. You will have to amp that signal of course, but yes it is just possible to perhaps manage that. I managed to hear -130 db on a 3 khz tone using headphones with a shaped dither in 16 bit file. I could hear -120 db with triangular (or near flat dither). So that dithered 16 bit is capable of portraying lower than -96 db and his claim of near equivalent to -120 db range isn't wildly wrong. I wouldn't quite characterize it that way. But then every time the subject comes up it seems confusing to people.
By the way your complaint about UV22 pushing noise into the 18-22 khz region being a problem also doesn't quite matter. Our thresholds for hearing those tones is very high in the first place. If you put noise there, it can still be below the point at which our hears would hear a tone even without noise. Which allows a lower noise floor in the frequencies at which we can hear with a low threshold. So human hearing actually doesn't have a dynamic range that is even over frequency. That is why shaped noise is audibly better than a flat noise spectra.
I can show you FFTs where the tones are visible even though lower than the RMS 20-20khz value of the noise. I can construct a sample file and send it to you. But it sure is a shame this kind of confusion happens many thousands of times over and over to only have someone anew make the same mistaken complaint saying it just can't be so.
The same conditions apply to LP noise. But the LP noise is at a higher level upon playback. LP simply doesn't have the dynamic range encoding ability of CD. It simply doesn't. Recordings may or may not have more on one or the other, but the CD has more dynamic range to work with. With dither something more than 96 db.
I appreciate the sound of vinyl, but if we measure real world, real consumer playback I would hope you agree vinyl has to take a back seat as far as useable real world dynamic range. the topic of this post.
Now, while I do not have the best playback gear (and who does?) I can record an LP to my digital 24/96 recorder (which records and plays back at 24/96 no conversions) and play it back and the playback sounds the same to me. It captures the things vinyl does, it does not hurt then in any way I can hear.
Again though, the OP is not sound, but spec. LP does pretty good for itself and it is a fully mature technology, and not likely to advance as far as at the cutter end IMO.
Now, if digital (not just redbook, but digital) is such a more measureably accurate reproducer of sine tones, and if I record LP to it and play it back it sounds near enough identical for me, but, folks who master it master it for cars, then that is not digital fault. And yes, digital is what now, 30 some years old in the consumer market, and has been steadily improved over time.
Its like tape, digital far exceeds tape, but folks like that tape effect, odd ordered harmonics and extra splash on peaks and less separation and etc, just like the less steller specs of consumer vinyl sound pretty darn good.
Do you use a digital delay in your chain? Just funin Atmasphere.
OK, so what were we talking about.....ahahahahahha
I think this is where the problem might lie - are reproducing sine tones a good way to determine how well it will behave with real-world music? As Opus11 used to say, it's about the crest factor of music - "my gut feel is we need a multitone test waveform rather than a single sinewave as a sinewave has a crest factor quite unlike music and if a sine provoked the condition we'd see it on the 'N' part of a THD+N vs level test."Hmm, I hear you, but I also sense quite a bit of sugar-coating. For example, how can you hear a -130dB 3kHz tone with 16-bit shaped dither if 16-bit cannot even encode such a signal, or to encode it as you say, it has to be amplified. But let's leave semantics aside: can anyone mathematically prove digital's alleged superiority when it comes to dynamic range.
