I get what you are saying esldude but I don't see how you are reading that into Don's quote. In order for you to say what you are there has to be some sort of leap in logic and apparently I am less willing to do that than you.
Text in bold: No, you have misread my demeanor.
You *might* want to consider that this comparison may not have given you accurate results- I would consider doing it again. FWIW, I compare analog and digital at every opportunity. We usually have state of the art gear at shows and I tend to do a lot of after-hours listening. IOW what I am saying is that there is something to be said for staying current. The current DSD systems are very good, much easier to live with than the best digital of only a few years ago. In the old days I judged digital by how long it gave me a headache- in the early days that was about 30 seconds. It was 1998 before I finally heard a digital system that would allow me to be in the same room all day long without physical pain. When I was in my 20s I could hear up to about 24KHz, ultrasonic motion detectors were really painful back then. Advances in technology and the degradation that comes with age have both helped me out when it comes to things digital. But only 2 years ago I heard a DAC at RMAF that gave me a splitting headache after only 30 seconds, so some of my upper range must still be intact...
One thing that has come out in spades in the last few years now due to downloads and hidef is the difference that often shows up depending on how things are done. For example, there are a number of sites that offer hidef downloads; some are a joke and some are excellent (Acoustic Sounds being an example of the latter). IOW you might think you are getting a hidef file when all it is is a redbook file repackaged.
Depending on how you have your programs set up you can also have really variable results (for example you may think you are running hidef when that is not the case at all...). I don't doubt that the ongoing confusion in the marketplace (PONO, anyone?) is why new vinyl is so easy to find these days.
So you imply I am hiding info. If I were making this up I would pick detailed examples more impressive. The lack of mentioning the cartridges is I don't remember them with clarity. They were properly loaded however. One was a MM. two were MC's. A SOTA headamp with adjustable loading was in use for one. A Music Reference with adjustable loading was used for the other MC. The SOTA arms I also am fuzzy about. One had the arm changed about then and I am not sure if it was before or after this as this was a few years ago. I believe one was a Graham and the other an SME. The Rega wasn't a reference in its day though a good little table within its capabilities. The Rega later had one of those arms with the silicone damping fluid in a cup which I also find the name escaping my memory. But that was after this format comparison period. The apparent differences in the format of LP vs CD and tape was enough to swamp any such little issues.
As for the pressings in use, all were good pressings from early on. In my group of friends were some knowledgeable collectors of both LP and reel tape. We did the comparisons for fun and to learn something. I wasn't a proponent of digital at the time though it was one of the experiences that nudged me in the direction of using digital more.
