Has anyone compared some of these cartridges? Impressions and preferences? Thanks
Hello Number95,
Thank you for your comparison. From what you said, it seems that the ZYX Universe II is similar to the Air Tight Supreme (more flow and musicality) vs. Lyra Atlas (faster, with more detail and extension).
What do you usually listen to?
Cheers,
VPN
I have had Lyra Atlas for a couple of weeks to test with my setup. It was mounted to Graham Phantom B-44 and then to Graham Elite (both 9 inch armwands). Then I got Zyx Uni II to try with same set up (this time both on Ikeda 407 12" tonearm and then Graham Elite 9"). I did not have both of the cartridges at the same time but Zyx came right after Lyra so I believe I can make a fair comparison at least to my ears. Atlas is extremely fast, also transparent and analytical (similar to Jfech's feedback) while Zyx Uni excels on flow, neutrality and a soundstage and air hence a realism to hear to believe. I thought of having Atlas but I also had Ikeda Kai which is another excellent sounding cartridge and even tough they had different virtues, I decided that I can live w/o Atlas even if I knew I would miss it. When Zyx arrived and after hours of listening against Kai, to me it was obvious that I needed to keep Zyx, no ifs no buts. I have learned thru many examples that cartridge performance and evaluating different cartridges are very system dependent. For my system and to my musical preferences I have found Zyx upgrading the system to a higher level while providing sheer musicality such that first time since I have been testing cartridges I stopped thinking about audio jargon and I keep listening to vinyl over vinyl.
I think no one can make a mistake to have Atlas or Uni, both are examples of finest cartridges over the planet. I think it depends on personal tastes and rest of the system to decide.
Number 95: How would you say your Miyajima Kansui compares with your ZYX Universe and the ones in the original post? I have been looking at the Kansui and ZYX and have the Triplanar VII arm.
Thanks, Barry
I have not listened to the Air Tight or the Atlas in my system, so I do not know how they compare to the ZYX. But... the ZYX is a strange cartridge. I hate the way it looks and feels. The Atlas looks like its a million bucks the ZYX 400 bucks. The ZYX does not do anything sonically that really stands out for me, but what it does do is lets me enjoy my records more than anything I have heard before. I just melt into my chair as the music flows through my body. I think very highly of Ortofon's MC Anna, I have one of those too. The Anna sounds like digital done right, a great cartridge but seems to lack some of the soul I hear with the ZYX. The ZYX reminds me of the Ikeda 9TT, just a fair bit better.
Wow, yes, right on the nose number95. Well said, I wish I had a way with words like you. I was an A student in math and D student in english!
