Ll , the set are in for review at AudioTechnique HKG , will let you know if any feedback . Not sure the Empress double crown has a grounding scheme incorporated .
What they do have is something called a Zero Ohm link , which incorporates some sort of grounding scheme . You plug your I/C into the Link , the link into your gear . Crystal has something similar called a Crystal Cable Bridge .
Thanks! Maybe you're right...I thought Audiocracks new cables were Empress...but I think they were Tara Labs something else...
Saw siltech triple crown in HK. For the ultra expensive price siltech is charging I thk workmanship of the cable is not upto mark. However a friend of mine prefer Siltech double crown to quite a few high end cables in his high end syst , very similar to Lincoln cheng 's Audiotechnique syst except Lincoln uses Tripoint troy , my friend like entreq silver tellus with Atlantis
Taralabs grandmaster evolution. Is the new top of the line Taralabs cables with dedicated grouding stations for the ic.
The RCA and XLR connectors on these cables looks very interesting....Siltech seems to have done some extra engineering here for a reason...
