Wake up on the wrong side of the bed Tim?
No just keepin' it real. F1eng, I hope you saw my tongue in my cheek there.
Tim
No,
I'm talking about the opposite.
Maybe we need to distiguish between 2 types of crosstalk at least:
1. crosstalk in analog circuits between channels
2. crosstalk from hearing the sound of two (or more) speakers with each ear
For 1) we have learnt for long time that we should avoid it.
For 2) we have different approaches to solve the problem, e.g. RACE and BACCHamongst others
I'm talking now about 1) The digital world does not know about crosstalk. Maybe we get it at the end when it comes to DA conversion and analog amplification. IMO this is a possible reason why the digital playback sounds digital and a perfect playback (free of crosstalk) worsens the result.
So it seems that a bit of frequency dependent crosstalk helps and it is recognized as comfortable, less nasty and more relaxing. IMO a possible reason is that the frequency dependent broadening of stereo playback gets reduced. A better localization relieves the brain.
So I'm talking about adding crosstalk which is the opposite of cancelling crosstalk
- Uli
I could not let this pass. Its patently untrue. What is true has to do with out-of-phase information, something that rarely if ever shows up with a live recording. But if it does, and is so bad that you can't get around it by changing the level slightly or cutting a deeper groove, the processor that takes care of it will only make the bass mono for a few milliseconds at most. I've often thought we would need such a thing (which BTW is otherwise a passive device in the signal chain) but so far have yet to see a recording where this is required. So every stereo LP we have done also has full-stereo bass.
Analog tape can do full output at any frequency within the passband. LP you do have to watch it, but it is not as fragile as suggested. But there will never be a full output signal at high frequencies recorded in any media except for testing- most tweeters don't handle more than a few watts for the same reason...
FWIW the RIAA curve does not specify a high pass filter beyond that of the curve itself. There are such filters in use but they are not part of the RIAA curve.
Actually I am very aware of how cartridges playback and their interaction with the arm! All mastering engineers have to understand the limitations of the playback apparatus.... The mechanical resonance describes the lower limit of any LP playback system. Upon listening to the digital backup we found the 8Hz (or thereabouts) to be a foot stomp, with exactly 1 sine wave iteration. It was at low level, and since we were doing direct to disk there was not a lot to be done about it.
In practice I've never had to compress any classical recording I have done. If you can put it on analog tape, you can put it into the LP too, as it has wider dynamic range than analog tape does, with a lower noise floor.
I am of the opinion that the highs of the LP are preferable as there is less distortion of the types that are annoying to the human ear/brain system, and otherwise less phase shift with more bandwidth.
This despite that fact that we were playing back **outside** the normal 12" diameter since we were cutting on a 14" lacquer, and the tone arm geometry is pretty poor when you are tracking that far out from the center of the disc. This is a handy technique if you want to get an idea of how your cutting method is working in a situation where you can't/won't play the actual LP region of the lacquer.
BTW, what do you guys think of linear tracking tonearms? Ive heard a version of this air bearing linear tracking tonearm & was mighty impressed with the tracking & the sound. Compared very favourably, if not bettered a unipivot tonearm
I am a digital dude. But I can't deny that sometimes vinyl systems can offer something digital struggles to deliver. We often hear folks pay a compliment to digital when they say it sounds "analog."
I love using DSP in my system. Recently, I switched over to Acourate.
http://www.audiovero.de/en/acourate.html
Since then I've been introduced to a setting in the Acourate Convolver called "flow." The basic idea is to set the parameters to permit some small frequency dependent crosstalk. The author's words explain it well:
http://digitalroomcorrection.hk/http___www.digitalroomcorrection.hk_/AcourateFlow.html
In summary, Uli's theory is that vinyl's perceived technical weakness (high cartridge crosstalk) can actually be very beneficial to better stereo reproduction.
I've tried it out and I really like it. It's not a huge difference. However, the music does sound a little more natural without any loss of resolution. It's cool!
Can DSP really be used to make digital playback sound more like vinyl?
Michael.
The air bearing linear tracking arms I've heard have great imaging and spaciousness at the cost of bass, dynamics and body.
DJ is Acourate "better" than the Spatial computing approach? Have you heard Spatial yet?
