Fair enough. I'll leave it to Max, who is doing fine work here. Did we agree that you were wrong? No...probably not.![]()
Tim
Is this a tag-team or something?
I also agree to disagree with your Artistic Director.
Tim
I'm finished with this - I think you know what the answer is & don't need to ask - uncontrolled variables = what?
The most important variable by far is knowledge, closely followed by volume level.
The rest are not anywhere near as important.
I also take exception to the sort of remarks that seem to percolate through these posts - remarks that suggest listeners are been taken for fools by knowing manufacturers/retailers in audio.
Rob, that control of (or in most cases lack of control) of biases was what MOST of the rest of my post was about..Hello John
It's not about being a fool, it's about not being in control of your own biases. That's the point of blind testing. Removing sight based biases, whatever you want to call them be it expectation and so on, has a significant effect on the results. Check out Tooles book Chapter 17.5 Bias from Nonauditory Factors. Just read the whole chapter 17 Subjective Evaluations if you have not already.
Rob![]()
I find that too much emphasis is focussed on sightedness & it become the only variable that is considered worth controlling. The other variables/factors are not given due consideration (I know volume matching is considered) but I'm talking about all the many psychological cognitive factors that can influence the outcome. Look at the short list esldude gave for long term testing - these don't go away in blind testing - these don't go away in short A/B testing. My preference for long-term listening comes from this very point - it normalises these influences & doesn't introduces new ones - the ones that Amir detailed & most people feel when being "tested"
My point has always been unless these factors are controlled then the the test is not valid. So the debate has become which is the better INVALID test.
Let me go back to how this long-term listening topic started in this thread - as Tim reminded me, it was Ron Party who posted this " I was speaking, perhaps ineloquently, to the claims we've all read that long term and not short term listening is what is required to reliably and repeatably detect certain differences." I think he was to trying to ascertain just how significant these difference were to long-term listening? Well, we have a body of people who claim high-res is significantly better sounding than RB. They have formed this opinion over long-term listening. So are these people now proven to be correct seeing as these ABX results confirm their claims. Or are you going to tell me that they just guessed correctly? How do you know?
My PS thought was a PS because I notice that a theme tends to run through some of the posts, Rob - it wasn't my main point, just a PS
A perfect example of per absurdo argument is " if this is not perfect then it is not valid". Wouldn''t you allow us that given two tests both of them imperfect, that the one that is less subject to biases would have the stronger probaility of being the better, conservatively 51% ? In that regard does "long term" qualify when the multitude of extraneous factors is enough to remove the notion of "test' from the activity?My point has always been unless these factors are controlled then the the test is not valid. So the debate has become which is the better INVALID test.
My preference for long-term listening comes from this very point - it normalizes these influences & doesn't introduces new ones -
Well let's look at esldude's, list of factors & consider if these remain fixed from day to day over a long-term listening (not to mention that they are NOT the same for everyone)?Hello John
Well they don't really change do they?? That's the point. All the "pressure" is there either way if you are more worried about fitting in with the crowd, proving a point, or just being honest about what you can actually hear. Being honest in front of this crowd being the most difficult.
Ambient noise levels at times of day or times of year.
Weather variables which cause noise,temperature and humidity variables even indoors with HVAC.
Personal stress variables from many sources like:
Your daughter's new boyfriend, unhappy spouse, vacations or lack thereof, unexpected expenses of living, expected periodic expenses of living, changes at work, changes with close friends in all these areas and their effect on you, relatives in a myriad of ways. Along with a lowering of stress from the opposite of all these or when good things happen.
Industrial activity in your area varies by time of year, day and weather which also effects low frequency ambient noise levels.
And on, and on, and on, and on, and on .......................................... this list being not even 1 tenth of one percent of the categories.
I didn't say normalises differences, I said normalises the influencing factors. Let me use this very apt example - the factors interfere with the correct sensing of the actual signal, right. These factors are many & varied & change from person to person, day to day (not all, but a lot do - see esldudes' list).Do your really think a technique that normalizes is the best for finding differences?? Seems to me it would do a great job at masking them.
So your "house sound" wasn't arrived at through blind listening, right? It was arrived at over long-term listening, I presume? Did you find that it fluctuated from day to day, depending on influences? Does it fluctuate now based on any of the factors that have been mentioned? Do you have to close your eyes to be sure that your system still sounds the same?To a point I understand what you are saying I have my "house sound" that my systems are voiced too. I had a person tweak an EQ I knew it in minutes that something was up. We have all had issues where this or that was off and you know right away. I am not saying it is not useful just not the best way to look for differences that may not be obvious to the casual listener.
Rob![]()
I mean exactly that Frantz, as everyone knows - visible knowledge removed - no grasping here. But there is a distinction here & possibly why I'm reluctant to use your "knowledge removed" phrase. Just how much knowledge is removed? If I still know I'm testing cables, then all knowledge isn't removed - my expectation biases are still in play, same applies to amplifiers, DACs, etc - knowing what is being tested is biasing knowledge. So the phrase "knowledge removed" is a pretense - it doesn't really mean what it says.John
Allow me to look more into your post.
The OP was that under conditions of blind testing, that is knowledge removed not of a person being actually blindfolded, severalpeople were able and that with a high degree of certainty, to hear clear differences between Hi=Rez and lower rez. I believe the most important aspect is knowledge removed not sight as you are grasping to that notion.
I differ from this view. If done over time the influence of factors will be averaged out (see my FFT example). If I did a test on a particular day then the factors at play on that day have more of an influence on the result then if I did it over a week, a month (presuming factors change). Multiply this by all the people doing long-term listening & the factors become normalised - no one factor becoming more influential than it should normally.I would think that the post by max made it clear long term: There are too many factors and they add up , they don;t normalize, they can't normalize since you have no control over these
I don't know what you are saying here?and remember you know the products in question.you compare this to training ... You would have to admit that it is stretching to the limit of most human mental elasticity ...
Yes, if it's not valid, then it is not any better than anecdotal evidence, is it? You are arguing that even though you accept the test is not valid, that by removing a single bias, that it is more accurate or better test (with no control over any other factors/biases)?You then write A perfect example of per absurdo argument is " if this is not perfect then it is not valid". Wouldn''t you allow us that given two tests both of them imperfect, that the one that is less subject to biases would have the stronger probaility of being the better, conservatively 51% ? In that regard does "long term" qualify when the multitude of extraneous factors is enough to remove the notion of "test' from the activity?
Well, I'm talking about the body of people who have listened to X. Obviously if this is a small number then it doesn't have much value. And please don't bring into it the number of people who believe in flying saucers or miracles or whatever. We make judgements based on type of people & numbers as to whether we value their opinions. Is this not what happens on every audio forum - we ask for advice about X, judge the number of responses & the "quality" of those responses to reach a tentative conclusion which we confirm or otherwise.And when we talk about a "Body of people", how large is that body? and under what conditions did this "body" arrive to these conclusions? Wouldn't the absence of controls make their claim invalid from the start?
Yes, this is what the debaters here seem to miss - the tests are invalid but they are arguing that their test is more valid than my test - let's not even deem them tests, as someone said - let's correctly call them anecdotes - their anecdote is more valid than mineA great point, to which the answer seems dependent on preference and politics rather than absolute objectivity.
John Atkinson
Editor, Stereophile
John Atkinson
Editor, Stereophile
See rob's post above. The answer is only dependent upon that if you've forced reality into a very tight, black and white corner. Why would a hobby dominated by subjectivists suddenly become so ridged in this one, small area? People are bending over backwards to find a reason why a comparative listening method -- let's not call it a test; the casual listening being held up as the benchmark certainly doesn't rise to that level -- which eliminates many opportunities for bias is no better than one that begs for them. It makes no logical sense. The position is not "valid."
Tim
I completely agree, Tim..Why would a hobby dominated by subjectivists suddenly become so ridged in this one, small area? People are bending over backwards to find a reason why a comparative listening method -- let's not call it a test; the casual listening being held up as the benchmark certainly doesn't rise to that level -- which eliminates many opportunities for bias is no better than one that begs for them. It makes no logical sense. The position is not "valid."
Tim
Hmmm, are you denying the effect of psychological variables in masking the perception of differences? This is a new angle, please explainJohn, variables, such as we're discussing cannot alter a speakers output, nor mask differences .
Yes, and...............?Removal of knowledge is of paramount importance, then level matching. The former deals with the psychological and the latter the fact that louder is different.
Another interesting contradiction - Nocebo means that someone won't hear a difference sighted or blind so not sure what your point is?Nocebo is a red herring once listeners report differences sighted, and allowing for the fact that almost all blind-tests have a listening panel that include at least some believers.
Totally confused nowCan you state some variables apart from the three I've mentioned that, if not accounted for, could invalidate a blind-test, and why?
Tim, I agree it's not a test but how many people on audio forums do you see citing "blind test results" when they are talking about these forms of casual listening. So this is at least progress - they are anecdotes, that's all.
So to your point - why should removing one bias (what are the many that you talk about?) surely be better than removing no biases? It's an unfounded statement.
How is it better if any of the remaining biases, collectively or individually, are substantially influential enough to mask the difference?
The differences are still masked by the remaining biases so how can this be better?
Unless you can prove that the remaining biases are not of a strong enough influence to mask the differences. But then you would need to know what they are & measure them & compare the result with/without these biases. Oh, wait, you've just done a fully controlled test![]()
Max, I suspect that you are confusing terms here. "Not valid" means that the test is not of a sufficiently rigorous standard to provide a relatively accurate result. Your use of "invalidate" seems to me that you think I'm saying blind tests are irrelevant - I'm not - they are of the same value as anecdotes. But I don't dismiss anecdotes as irrelevant - maybe you do?I completely agree, Tim..
IMO, looking to invalidate virtually all non-sighted testing on the basis of it not accounting for enough variables
Again we are talking about anecdotal evidence, Max - we all agree that uncontrolled blind tests are not valid (even your SVP, Tim), just the same as sighted-tests.- whilst looking to validate sighted-testing even though it accounts for none, could be put under the Wiki definition of 'illogical'.
I'm not sure what this means or what your point is?Also, re John's point, aggregation of subjective sighted opinions along with non-sighted reports is pointless, IMO.
