R u kidding me ? Please state your case. You complete post fails to convince me.
Agree, a bit of stretch. But it is clearly different than PCM.
Learn. Do the research, the 30,000 foot view is not difficult. Here's some starter links. Do the table on the embedded.com link, and you'll understand more about DSD that the vast majority of "experts".
http://www.embedded.com/design/debu...-of-sigma-delta-analog-to-digital-converters-
https://decibel.ni.com/content/docs/DOC-4775/diff?secondVersionNumber=2
http://www.beis.de/Elektronik/DeltaSigma/DeltaSigma.html
Or take my word for it![]()
No, not all DSD DACs transcode to PCM.All DSD recordings are multi-bit - 4 bits one quarter as often or 8 bits one eighth as often. This has to be - in order to perform calculations on the signal, level changes, dithering, etc. You cannot dither a 1-bit stream.
Then DSD DACs - all transcode to PCM, despite the marketing claims made by high-end branders.
There's no misinformation here - only people who continue to be in the dark...
I corrected the "DSD DAC" thing, in my last post (is now "SACD players").
But the point stays the same...
Mmm...professional audio reviewer - who doesn't know this:
wiki.jriver.com/index.php/DSD_Format
Then, editor of Stereophile reporting that "all current generation DSD-capable DAC chips transcode to PCM."
This - in his review of NAD M50 (earlier this year, tail-end of review).
This underscores (two) of our problems - misinformation (from brand co.) then people *accepting* these claims as truth.
The jriver link was updated as recently as this year - right in the "history".
The DAC chips - "almost all" is close enough. One freak DAC-chip (that doesn't transcode) won't cut it. Listeners of SACD are hearing *PCM* - as processed before conversion to analog.
I am not going to challenge John Atkinson on facts pertaining to the audio industry - but you could if you want.
...believe what you want.
you cannot wiggle your way around the FACT that DSD requires an analog to digital conversion (a Digital domain process). That is not analog. Sorry![]()
Has anyone got the chance to compare the this PS Audio DAC to lampizator's? Any thoughts? Thanks.
`For the DAC chips -"almost all" is close enough. One freak DAC-chip (that doesn't transcode) won't cut it. Listeners of SACD are hearing *PCM* - as processed before conversion to analog.
Well, is there an answer to the question above?
