... Dudley used to be a great..
Fixed that. Based on much of his last year's published writing I'm afraid he might have suffered a significant loss in his cognitive facilities
Fixed that. Based on much of his last year's published writing I'm afraid he might have suffered a significant loss in his cognitive facilities![]()
tailspn please do not ruin my day; I love the forum conclusion reached that nearly all SACD/DSD is transcoded to PCM and also nearly all PCM DACs convert to SDM![]()
According to the manufacturers, at least Cary, Playback Designs and Oppo will all decode DSD directly to analog without PCM conversion. I'm sure there are others, those are just some that have come up in recent discussions.
I won't ruin you day Orb, honest.
I believe the debate on this thread is about semantics. Thinking that multi-bit PDM is PCM. j.phelan is correct in that many DAC chips transcode the 1-bit two level bit stream decoded off an SACD into multi-bit. But they do that at the 2.82MHz bit rate, or a multiple of that. They do not decimate it down to a digital value based 2's complement binary PCM word(s).
Confusing multi-bit PDM (Pulse density Modulation) that has no absolute digital word amplitude level value(s) with PCM that is only absolute digital word amplitude values, is what I believe the fundamental misconception..
Orb said (as a "conclusion" of this thread) that "nearly all PCM DACs transcode to SDM". I didn't say that, for one.
But two, if we listen to the tech guru of AMR, there are no true 1-bit DACs.
Many high-end DACs don't do this anyway - even as advertised. Zanden, MSB and Totaldac are a few.
But two, if we listen to the tech-guru of AMR, there are no true 1-bit DACs.
And - it should be noted that many high-end brands don't even (try) to do 1-bit - Zanden, MSB and Totaldac are a few.
Definitely not directed at you J-Phelan and I could had made it clearer, sometimes forget readers may not be aware of previous discussions.Orb said (as a "conclusion" of this thread) that "nearly all PCM DACs transcode to SDM". I didn't say that, for one.
Was this when he was one half of Deltec Precision Audio' (DPA) in the 90s?Rob Watts did his first FPGA DAC I think 1997 (before Chord Electronics and DAC64 that enabled him to take the design further and more commercially)
Probably one of the earliest examples of bespoke DAC using FPGA, whether first to do away with traditional OEM DAC Chip *shrug*.
Cheers
Orb
