I agree I am on my third Audio desk I have no thoughts of this as as a long term machine. It is not will it fail, but when it will fail. Easy to use and it cleans well but this breaks down as often as my mercedes ml 500.
I know that all the rage for you high-rollers is the KLA and the AD, but I'm really liking the Nitty Gritty 2.5Fi that I recently acquired. As you may know, I was using the manual Spin-Clean since I needed something....anything. I've been playing around with various methods in the cleaning cycle and decided to stick with a very basic formula. I first do a simple manual clean with the Spin Clean and let it dry. I then use the NG for a deeper clean and vacuum. I've been very pleased with the results and do not find a need to extend my regimen by rinsing after the NG clean cycle. Some will say that's a mistake on my part, but I'm not concerned about it tbh. I've never done it before (other than during this trial testing period) and have found no difference in sound quality or detrimental effects to my LP's.
I know that the VPI 16.5 gets most of the praise in this under $1,000 price segment, but I wouldn't trade the NG for it...no offense meant towards the 16.5.
Guys Alcohol can make records sound better but you do not put it on the records.
Alcohol can damage records, at least it could a millenium ago when I was better versed in such things. Is that still true?
That said, I think the new enzyme based record cleaning solutions produce better results.
I'm convinced that my NG 2.5Fi is introducing static after a cleaning/vacuuming. It's not audible static, but rather the fact both my felt and foam mats are sticking to the vinyl when I remove it from the platter. It's driving me crazy. I bought a cheap Pro-ject Cork mat yesterday and will try that out a little later today.
You might try reducing the number of revolution times while drying to the minimum necessary.
like no more than 3 revolutions under vacuum.
