And the answer is I DEFINITELY have some screws loose...I'm an audiophile!
Does changing; say a phono cartridge, which can change frequency balance mean a change in speaker position would be beneficial?
Please remember that changing speaker positioning is
easy and one can always go back to the prior position...so experimentation is warranted, IMO.
Easy is a relative word. It depends on your speaker size. Large 650lb. Per channel speakers are not easy to reposition.
I see where you are coming from. That said, spiking them or adding Ultra 5s makes a BIG difference, and it seems a shame to go thru all the cost and braindamage...not to set them up optimally. Yes, not practical (as many of us have been reminded by our wives)...but totally worth it when set up just so!ive noticed owners of mammoth sized speakers more often than not keep them on casters. if I did I would.
that's the question of the day: does the benefit of spiking the speaker more than offset the ability to reposition at will to maximize performance - I would add, for those that enjoy more than one type of speaker in the same listening room casters are obligatory.
there's a product idea for someone, audiophile approved casters that provide similar attributes of floor spikes.
You're supposed to find the Goldilocks spot while the speakers are on casters and then spike them to the floor unless you are neurotic and can't stop trying new locations that are 1/64" in all directions from where you originally landed them after spending 6 months finding just the right spot.
They don't sound nearly as good than when the speakers are on spikes or better yet, Stillpoints.
John, you may want to tilt them in more than 3/4". I would suggest trying an angle that is between 30 and 45 degrees from the straight ahead position. The tweeter should be firing to just outside your ear. I would suspect that 3/4" isn't enough. However, do mark each position before you modify ( I use blue tape), this way you can easily go back if you don't like the result.
John, since you have the rear tweeters off, my usual recommendation of never toe-ing in doesn't apply as they are no longer dipoles.
You will only know that you are making improvements if you know that the music you are evaluating the changes with do not have a center image that is muddy and thick to begin with. If you gain focus on a recording that already has a thick center image, you may end up with a pinched center image with a recording that has already a good center image.
The wavelength of sound where I cross over the tweeters is about 4". If toe-in the speakers by 3/4", a laser pointed at the listening position will be deflected more than 4", so the increments of toe you make at the speakers should be finer than 3/4". Another thing to do is to move the speakers closer together/further apart.
Because the dispersion of the tweeter at 18kHz is the same as the dispersion of the mid/bass at 3000Hz, the G7f's will behave very different from Davey's Guarneri Homage.
