A little tip for those of us who use banana plugs, try screwing off the outer casing of the speaker plug on the amplifier...
what are the benefits of the above?
Well the quick answer is that it sounds better! you get less useless mass in the plug itself, kinda the same idea that's behind the WBT nextgen and Eichmann plugs.what are the benefits of the above?
It's easy to try and if you don't like it you can screw the plugs back on so it's a completely reversible tweak.
not sure i could pick up the difference and my handyman skills are not exactly great
It's just a screw it doesn't take much in way of handiness and if you can't detect the difference you're probably in the wrong hobby![]()
Stock power cords???
Witch one are you using Ekmanc ?
Nordost will make one with plug who fits back on the Devialet,did that with a Frey 2![]()
Hi Ekmanc,
is there a trick ? I can not fully remove the outer casing, it's fixed in the plastic part somehow. Don't want to destroy something...
I know what less metal mass can do, I'm also using WBT Nextgen speaker terminals which is clearly audible.
thanks, will try that tomorrow. Just enjoying the big improvements in SQ from the new firmware...
