Have you been using Tact's RCS or TCS, but have since switched to some other solution, what alternatives did you evaluate, what did you switch to, and why?
Currently still using Tact. Looking for a replacement also as Tact is no longer. This comes highly recommended though I haven't tried it yet.
http://www.audiovero.de/en/acourate.html
Depends whether you want a hardware or software solution and how far in RC you want to go - IMHO RC is totally a waste of time above 250hz or so , it doesn't really correct anything.. you need physical treatments and not electronics for lower mids and above , RC DOES correct really well at the sweet spot for bass - only at the sweet spot tho - if you want to correct the *room* overall in respect of bass , you need multiple subs , physical room treatment etc.
Hardware works with anything generally , software can be cheaper - or pricier- and is specific to the playback source , you pays your money and takes your choice...
I have used Sigtech , Tact , Behringer , Z-Sys RDP-1 , Lyngdorf room perfect, KrK Ergo , Meridian MRC , Audyessy , Dspeaker antimode 2.0 and currently a miniDSP openDRc - di (and a few software solutions.. Tried Dirac etc)
I cant tell you which is "best" , all have their foibles and sonic signatures... currently I have found the Dspeaker antimode 2 exceptional for bass , but due to its parametric eq being very user unfriendly , I am using the miniDSP in conjunction with it for tuning 120hz and up for taste . Dspeaker is by far the easiest to set up and is self contained and IMO has almost no sonic impact in bypass mode..one has to realise that these units are not used in bypass mode and they operate on the signal and change it .....
There is a slight loss of some "air" with both or either systems in line , but the other benefits they offer outweigh this and the improvements they wring out are orders of magnitude above their small faults..
Most transparent DSP parametric I have used is my Z-sys RDP-1, however it is just a parametric (often a parametric is enough to cure a lot of bass ills)
My system might not be flat (or correspond to the B&K ideal listening target curve at the sweet spot) but it's really my own ears I have to please , so I do tweak it after the "correct" correction
I am currently messing with AcourateDRC used to generate FIR filters for my openDRC RC unit - still got a while to go till I get it right...
I agree - a lot of choice these days, and various combinations of hardware and software. Man, you have tried them all! A lot of stuff to mess with, learn and apply. Thinking of going HTPC and software to get it all the digital stuff in one unit but using external units for DA. As for foibles and sonic signatures I'd be most interested to hear more about that. Specially Tact vis à vis DIRAC. Giving up on Tact, was that because Tact focused on correcting the entire audio spectrum, rather than just bass frequencies, and that this imparted a sonic signature? You mention miniDSP, and I noticed they have announced a forthcoming unit with DIRAC on board... (EDIT) Just noticed it looks like a stereo only unit.
