Commercial product? My guess is the Boulder 3050.
No amplifier deliver 300 w REAL class A from a standard AC installation.
Interesting & I am not doubting you.
Does any amplifier deliver 300 w REAL class A from NON standard AC [or DC] installation /// 220v, 440v, 3 phase, High Voltage DC generator ?????
Thank you,
zz
Pass Labs XS300 claims 300 watts of Class A. The XA200.5 claims 200 watts of Class A.
Nelson Pass makes great amplifiers.
I read the manual on the XS300. I initially copied 2 paragraphs, but deleted them due to ?copyright issues? - maybe.
The pdf manual is easy to download & read.
Near the end the meter is mentioned & and I will quote here: "when the output current of the amplifier exceeds the Class A bias
setting, you will see the needle bounce upwards."
"exceeds the Class A bias"
Great amps / I am not solid state technical enough to continue.
zz.
The XA.5, XA.8 and XS series each deliver their full rated power as Class A into 8 ohms, double that into 4 ohms. They have an additional 6 dB of A/B power (or slightly more) available above that rating.Yes, it is my understanding that these Pass amp ratings are for Class A power before they go into Class A/B. My XA160.5 for instance has 160 watts of Class A into an 8 ohm load and 320 watts of Class A into a 4 ohm load. But they have much more additional power once they leave Class A. The XA30.5 was measured by Stereophile and found to have something like 130 watts of total power in Class AB, but at least 30 watts of Class A into 8 ohms. I can't remember the exact number, but the rating was found to be very conservative.
Didn't Stax make some monster Class A amp back in the 80's?
someone once told me that typically most pure Class A amps are pure Class A into their 8ohms loads, and will double watts into a 4ohm load, but the amount that is still Pure Class A actually HALVES...so a 100watt/channel Class A amp will be 200watts into 4ohms, but 50 watts of that is Class A.
I am NO techie, so thanks for any clarifications here.
Gentlemen, other than the recent Boulder and Krell innovations that Amir mentions, why did the others stop at 150, 200, etc.? Is it just because your room would turn into a sauna, or for sonic reasons?
