Parallel, Simple, Effective
I have a little over an hour on the Typhon and... years ago, I determined Power Conditioning was not for me - simply, most products are junk... in series, convoluted, they give you something and take away something else, you get the drift. Then I set my requirements: Parallel, Simple and Effective. The Equi=Tech isn't that, and I know it's effective, but it's still in series. So does such a thing as a P.S.E. exist? Hadn't found it.
The Typhon/Triton have garnered a lot of attention here and elsewhere. I don't care for long posts, so I'll be brief for now:
This is gigantic improvement, and the manual says I have to let it settle in for 5 days? The question is how do I get another one in 5 days. More in 5 days...
PS: Shunyata "seals" a couple of the top screws with glue... that was funny !
- The dynamic range gain is phenomenal. Steve said ~4dBs??? Even more here; your tubes are showing their age???
- Beyond a certain [high] volume level I always wanted to turn the volume down - now I want to turn it up; the distortion level is much lower
- The feeling of presence is phenomenal
- Instrument separation to yet another level
- More depth? Sure
