Too bad you didn't have the proper XLR cable. The lack of extension in HF and a sensation of superior transparency is often what differenciates the avg and trully hi-end cables.
Sure, just sent them back the other day, so the darTZeel is playing non-stop again...
A few caveats: I got a 110V unit, while I usually prefer to run my amps on 220V. I do have separate taps for the amps, and 110/220V taps too, so the power was clean for both, but perhaps the Constellation would've run better on 220V. Also, I tested the stereo. Monoblocks could be quite a bit better too. Last thing, cables. I had to use a cheap XLR to connect the MSB to the Constellation pre, since the dealer didn't supply me with the long cable that I needed. The darTZeel was properly hooked up (RCA) with Kubala Elation cables.
Are you addressing the DartZeel NH 108B or the monoblocks? Can I ask what was the "cheap XLR" ?
First, let me tell you what surprised me: it doesn't sound as "powerful" as it should. I mean, 500W and the darTZeel has more slam.
The biggest difference to the darTZeel is on the high frequencies. The Constellation gear is simply not as extended. It makes the sound "nicer" with bad recordings, but it does obscure some of the ambience retrievel magic that the darTZeel is capable of.
It's also more generally laid back than the darTZeel, which is a more "nervous" and in-your-face. The sound stage was presented waaaay there in the back, while the darTZeel adds more layers. Again, for badly recorded music, it's "nice" to have the music presented calmly there in the back, but I prefer a more natural presentation, even if that means "in your face" sound.
It can't touch the darTZeel on sheer naturalness as well, perhaps because of those little deficiencies. Voices and instruments are just more palpable, more real, with the darTZeel. Imaging was about the same for both, not absolutely crazy pin-point 3D imaging, but that's not something I look for much anyway...
On certain material, I found it to have a little more mid bass presence, a little more energy around instruments and voices. Again, the perception was of a "nice" sound, thick and full, yet detailed.
Overall, the gear left a very good impression, mostly because it managed to get very close to my current preference. It manages to be very transparent, while also being a little dark (that lack of HF extension).
I'd buy these if I didn't have the darTZeel. BUT, I still haven't heard the current darlings, the D'Agostinos
alexandre
On an XLR, shouldn't make that much difference.
Uh...yeah. If you really believe in an open discussion and you really believe it's "all good," it's probably not good to begin the discussion with the idea that if you're on the other side of these "differences," you're not a music lover, and have chosen is a thinner presentation. That's calling for sharing experiences that are all good as long as the full, rich, warm, fleshed-out club is free to insult everyone who doesn't agree with them. Sorry to be so blunt, but there it is.
Oh and by the way, the reason why linear performance is considered "more high fidelity," is because it demonstrates a higher level of fidelity to the input signal. It's not a matter of taste, and you don't have to like the way it sounds.
Tim
He probably had those on a long term loan ... loan ended, so he took another one. Nothing to be really exited about.
my observations as a non-techie who has read many a debate by designers, audio techs about "the best design" and best technical reasons why by measurements:
1. I am not convinced there is agreement that we know everything that needs to be measured to make a 'perfect reproduction'.
2. It does seem obvious that since there is no perfect reproduction, every design is a particular blend of compromises...and that effectively the kind of distortion one cares about or is sensitive to will vary by person and by designer. I would not be surprised if someone measured the equipment i tend to like, that we would find there are certain levels of distortion on certain things i don't care about....which someone else would hate...and some where i am incredibly picky and will not stand for anything that does measure."almost perfectly".
For example, we can talk about thd and someone will say look at imd. On an even more basic level, i have relatives with slight high frequency hearing loss...trust me when i say they do not care about inverted titanium dome tweeters vs silk dome tweeters...they just turn down the bass and turn up the treble so they can understand the news on the radio. Complete distortion...but that is probably perfectly flat response in their head.
So i find for me that the lack of consensus around great designers as to what to measure, and how to prioritize the amount or level of distortion of each kind of distortion...mixed with the fact that many of us may in fact hear slightly differently...means that while measurements are a great baseline...there is good reason to gauge by ear in the end.
My observations as a non-techie who has read many a debate by designers, audio techs about "the best design" and best technical reasons why by measurements:
2. It does seem obvious that since there is no perfect reproduction, every design is a particular blend of compromises...and that effectively the kind of distortion one cares about or is sensitive to WILL vary by person and by designer. I would not be surprised if someone measured the equipment I tend to like, that we would find there are certain levels of distortion on certain things I don't care about....which someone else would hate...and some where I am incredibly picky and will not stand for anything that does measure."almost perfectly".
For example, we can talk about THD and someone will say look at IMD. On an even more basic level, I have relatives with slight high frequency hearing loss...trust me when I say they do not care about inverted titanium dome tweeters vs silk dome tweeters...they just turn down the bass and turn up the treble so they can understand the news on the radio. Complete distortion...but that is probably perfectly flat response in their head.
So I find for me that the lack of consensus around great designers as to what to measure, and how to prioritize the amount or level of distortion of each KIND of distortion...mixed with the fact that many of us may in fact hear slightly differently...means that while measurements are a great baseline...there is good reason to gauge by ear in the end.
amen !!!
Hi Marten, thanks and welcome aboard...looks like your first post from what I can see. Hope you'll be joining and contributing further.
