Thanks so far. I am still hanging around with the cable question. Due to a need of 8 meters on the one side and about 5 meters on the other, it should not be to expensive. Additional to that I have to lead the cable through 20mm reserve conduits that doesn´t alow a diameter of a hose pipe. I don´t believe in cable voodoo that much on the one side but don´t want to loose sound quality on the other. We will have an other test especially for that with my dealer in a couple of weeks (hope to test the D-Premier vs Devialet 110 also). Searched through the internet a little bit the last days and found some advises for Silent Wire (LS 16 Mk2 or LS12), Fast Audio (Fadel Art Greylitz Mk II) and for MIT (EXP 1) also. My dealer recommends Audioquest. I myself had a cable of T+A (Speaker 6) so far. Heared about the WireWorld (Oasis 6) also. But I think it is to thick in diameter
I guess it will turn out to be an interesting afternoon.
What about the silver cables from "German Highend" , are they any good ?
Here in the UK Vertex AQ will make custom cables if you ask them but they are expensive due to the unusual materials used in the RFI absorption module.
