I tend to agree that if there is this "flabergasting" change in dynamics, it can easily be measured by an audio engineer. But, what is probably being heard is a possible change in the harmonic spray and that is interpreted as dynamics, and that can not be measured unless a comparison is made via the old and new supplies.
digital issues are in the end, actually, analog issues. and thus harmonic spray issues.
Harmonic spray?
As we've said before, jitter and noise are the biggest issues with computer audio; there are a number of older Mach2Music threads on audiogon about how a good power supply can reduce noise, and consequently improve the sound. This is real, not voodoo. I had posted a year or more ago that exactly because you can't really control jitter and noise in PCs, DIY PC-based servers are not for me and will never outperform an excellent transport; I have since then discounted any PC-based server for serious audio reproduction. There are also folks here who hear very large differences with digital cables between their PC servers and USB reclocking devices - all they are doing is really managing noise better.
We happilly spend thousand of dollars on Quantum dots but cannot get our minds to admit that a $500 contraption will wipe the floor with our kilobucks transports ... Wait .... that is exactly the problem .. if it is so cheap it can't possibly sound good .. Talk about a screwed-up mentality !! I am glad I took the plunge and I am not looking back .. I have never heard and enjoyed so much music since
Naaah... from a couple of discussions with the local dealer, they have also not been able to get close to top-transport level performance from the commercial music servers. Bernice from Spectral also said a while ago in the SDR-4000SL thread that they didn't include a USB input because of the all the noise. To me, a PC-based server is good for convenience and for playing hi-rez PCM digital, otherwise unavailable from high end transports. Just went back to my emails, some folks have also told me they heard huge differences between SPDI/F cables connecting the Berkeley USB and the DAC - basically, more noise seeping through to the DAC and managed by cables with in-series isolation transformers and all...
Don't you know that a $500. PC will wipe the floor with your transport?
Maybe you missed this statement from post #278 in Let's Talk Computer Audio thread:
If there was ever a double-blind test called for, listening to a properly set up music server against a stand-alone CD player or transport + DAC would be real high on the list. After all, DBTs have shown that people can't tell the difference between an English muffin and a NY pizza so straining to hear the difference between bit perfect players hooked to the same DAC should really boggle the mind.
Objectively, the measurements show superlative results when the right gear is used. Here is my standard work-laptop, with a ton of apps and stuff running on it, driving a Berkeley Alpha USB to my more than 10 year old Mark Levinson 360S Dac using async USB:Don't you know that a $500. PC will wipe the floor with your transport?
There is no cheaper and more convenient way to get into "high-end" audio than getting a good async USB and pairing it with the DAC of your choice. These devices get the best out of any DAC.
I didn't know "high-end" audio was defined that low$1,895 for a Berkeley Alpha USB converter is hardly a cheap way to get into "high-end" audio.
I heard them make that argument. It just isn't something I have experience with so I was not going to argue one way or the otherYou should persuade Berkeley Alpha that RHOS compliant solder sounds as good as the old poisonous solder they are using. They do not believe it ...![]()
I don't have an ML31.5. The last transport I bought was a decade ago, a Linn CD player, and that was it. I switched to PC playback and never looked back.I would love to have tried it when I hosted the Devialet. Did you ever compare the sound of the 360S using the Alpha USB with the ML31.5?
I didn't know "high-end" audio was defined that low![]()
. But sure, you can step down to Audiophilleo which I also test. Its performance is still superb. And it retails for $500. I have not tested others but there are much cheaper adapters down to $200 or so. You can take an obsolete PC that costs nothing and combine the two and you have a $300 "transport."
Oh, no, you can't go by the noise floor in those measurements.thats some darn good analog electronics punching down to -145 db, that near 24 bit digital performace. imagine all the music our sorry amps are not even able to reproduce....is it no wonder i am so tired of another year, another reference amp, that cant get past 100 db or whatever...
thanks for the pics Amir
