Looks sorta like Analog Domain...have you heard Analog Domain and these by the way, Wizard?
A review of Artemis is out.
I've seen the inside of Artemis and Apollo.
Both are using big blue caps - they look like the same that are used in A-300X.
It was certainly a good review. http://www.theaudiobeat.com/equipment/analog_domain_artemis.htm
Look at he reviewer's gear. It is no joke.
This is the latest version of A200; Reference S2.
It has 450,000 uF with capacitors and power output is 200 watt class A in 8 ohms.
Weight is 82kg each.
---- Man wizard, you always come up with the best pictures of the best audio gear and with the best audio specs!
-- Sir (wizard), do you listen to most of the beautiful pieces of audio equipment that you post?
Most (all) of them are true beauties and with specs to die for.
EDIT: I kind of knew it that it was risky to ask a question, but I had to try anyway. :b
My Magnus MA-300 looks almost exactly like the interior of the B-80. I wonder how the 2 sound against each other. The MA-300 is 160lbs and 600 wpc 4ohm.
Yes I've listened to almost all brands on the market, but not B-80 and A-300X yet.
But I've heard AM ref preamp and B-130 amps, and they are close up to the sound of FMA 268 and 1811 at a fraction of their price.
The Excellence products I think will beat all the FMA products.
AM, Trinity and two handfuls of other brands are part of the new generation of products that sounds better than the very overpriced older brands.
Yes Trinity known as GTE - their new cheaper products sounds better than the old tri-shaped products, and the new Trinity Phono sounds better than FMA 222 and 223.
Before I just bought the most expensive products on the market, and I thought I was getting the best sound there is, but I don't need that anymore.
Hi Wizard
Do you have any further details on the Trinity phono stage, besides the alternate riaa equalisation. What does it do better than the FM acoustic phono stages or others like Pass xp-25, ARC ref2 ss?
Regards
