the amount of insurance I needed to buy on that box was sobering... about $45K.
how much does that level of insurance cost roughly ?
Cables are an intersting thing. Everyone feels they sound different but no one can pick out their cable from another. I am sure I couldn't either but yet agree there is a difference.
UPS - 2%.
Fedex, not real "insurance", but Fedex assumes liability up to declared value at FAR lower cost than UPS insurance.
Hi on the Reference cables with MM2...pretty sure their is just 2 settings...lo z and hi z...so this links to your answer on no need to change... the Ref MM MM2 (their names are very confusing) is highly tuned to exact impedances...that's really the reason to buy that cable over the Ref with MM2. I expect you're in for a big improvement Lloydelee...
I also hosted a full set of Odin's with the power cables for a few days and the difference between my cables and this set was very large, but I must forget about it!![]()
A common mistake when comparing cables is mixing brands - the main characteristics wash and choice becomes more difficult. Comparing complete systems is the best way of knowing the cables signatures.
One point however should be considered - using cable tuned for an higher impedance unit is acceptable , however the opposite will seriously affect sound quality -e.g. usually a cable tuned for tubes can be used for solid state, but not the opposite.
Thansk, Microstip. So if my TA RefMM (MM2) is set for 600ohm going to 100Kohms...what is your opinion of it being used for 2.5kohms going into 20kohms?
Would I be correct in interpreting that statement as "I liked the Odin, but my bank account doesn't!"?
Just consider I use a 6m XLR cable between preamplifier and amplifier ... I need a cable where cost does not scale almost linearly with length! You see, I managed to find a nice rational excuse not to buy it ...
Lloyd,
According to what we have been presented the 600 ohm seems to be the high impedance output type cable. It seemed to me that for these cables TA only have two IC tunings : low and high impedances. I would expect that low would be something around 50 ohms, as most solid state units, and the 600 ohms would be the generic high output impedance. Input seems perfect. So it seems you have the correct version of the cable. But is is just my feeling, even less reliable than being IMHO!![]()
How does it sound?
my cable which is just below Opus MM2
You're 3 levels below Opus MM2
Opus MM2 > Reference MM MM2 > Reference XL MM2 > Reference MM2 > Ultra MM2 > Super MM2
EDIT::: Sorry, I think I misread. If you have Ref MM MM2 then you have far more tunable parameters than just the high / low impedance. Reference with MM2 is just a high / low cable.
Bizarre - when switching cables to compare...one of my TA Ref MM (MM2) cables is silent now. All inputs/outputs work with other cables. Its like the cable just went dead...is this possible?
It is if the cable opened up somewhere along the path. It would be highly unlikely to have a break in an open part of the cable run (from the amp side of the speaker terminals to the network box and from the speaker side where it exits the network box). If there is an open connection, I would suspect the break to be inside of the terminal box.
Sounds like you have compromised one of the cable ends to me, lloydlee21.
Tom
Hi AMP, yes i am Reference MM MM2. So I am just curious if 600ohm to 100kohm (current setting) really needs to be recalibrated for my setting (2.5kohm to 20kohm).
