To me that response reads like classic marketing bluster and obfuscation. 'Our DAC is so different the normal rules do not apply' is special pleading.
My comments weren't intended to imply it can't sound good Bruce. I fully accept your listening impressions.
Well, there's four possible scenarios for the JA's measurements of the MPS-5:
1) Defective transistor in analog section. If a bipolar transistor is damaged by heat or a voltage transient, it can become noisy (which precedes failure). The noise is characterized by bursts, growing worse over time. If the following stages are DC-coupled, the power amplifier can be destroyed by the DC pulses, and the woofer in the loudspeaker will also be damaged. (Even pro woofers can only tolerate 1 watt or less of DC offset, since the voice-coil cannot cool itself by moving back and forth.)
2) Unstable regulator; these can slide in and out of oscillation in the 1~10 Mhz range, and scopes don't easily trigger on bursts of oscillations. RF oscillations makes analog sections do bad things that resemble noise but aren't. Another possibility is a noisy Zener diode that's used as a voltage reference; these are usually bypassed with a cap to lower noise, but the cap might have gone bad.
3) Sub-optimum noise-shaping algorithm in the Playback Designs. This is consistent with the high level noted - no better than 16-bit resolution - but is not consistent with the 3 dB difference in noise levels between channels. You'd expect the algorithm to be the same between both channels. What is consistent with this hypothesis are the noise bursts - 1-bit converters are known for instabilities in the noise-shaping algorithm.
4) JA messed up the measurements somehow. There are many ways to induce ground loops in a measurement setup, and the low levels being measured will reveal this kind of thing. Bad connections in particular will show bursts of noise. Not sure if this would account for the 3 dB difference in noise level between channels, though.
In the absence of more information from either Atkinson or Playback Designs, it's hard to tell what happened. If the noise bursts - which is the most unsettling comment by JA - appeared in both channels, it's the noise-shaping algorithm. If it appeared in only one channel, then it would almost certainly be a bad transistor (or Zener diode). Unstable regulation could appear in one or both channels, depending on whether the MPS-5 shares regulation across channels or not.
The power-supply rails would have to be measured to confirm supply stability, and in the absence of a schematic or a board layout guide, not something you'd expect JA (or any reviewer) to do. Poking around randomly on a circuit board without knowing what you're looking at is a great way to short out a regulator and damage the review sample.
Well that seems to be the stance of the majority that has read the measurements. That's why I don't buy equipment based on listening with my eyes....
Did he expect that just taking the cover off he would find the fault?
A call to the manufacturer would have been the proper response. Something was wrong with the unit and something fishy with that review.
The *irony* shouldn't amuse you because I came to my conclusions based on listening to all of the formats in my home. I didn't come to my conclusions based on hearing one format while looking at a spec sheet for the other formats and making a decision on which one I thought sounded best.
How true. DSD is way better than Redbook/HiRez. in my system and who cares if folks want to say other wise. Send all the DSD files you think are less to me.
But ... then we get into the politics of dealing with a very powerful, well-financed magazine that has the power to bankrupt manufacturers if they choose to. Although Mr. Tinn's response is, well, non-responsive, it's always a losing game for the manufacturer if bad stuff appears in a powerful magazine. For all we know, Playback Designs may well have seen JA's measurements, responded with alarm, offered to replace the review sample, and Stereophile declined, running the review as-is. We have no way of knowing what happened here.
