Hi Andrew, on M625 and M725 the ball-footers are machined from Delrin blanks... Has this changed on M925? G.
Congratulations . Would be very interested in you thoughts on how they stack up , against the Boulder .
The real surprise for me is the performance of the Aeris DAC. I've been feeding it from the coax output of the Wadia 571 and switching between it and the Wadia 9 series. Although the Wadia has a slight edge in resolution (very slight) the Aeris is matching it in every other parameter and even exceeding it in a few. Most notably the Aeris seems to have a much more pronounced rhythmic drive to it and with that it's a lot of fun to listen to. Given the cost delta between the two I'm seriously considering switching and walking away with some extra cash in my pocket.... and a lot of free space in my rack.
..thanks for this insight: You had the s7i, which I still use (GNSC); I could never reason to go to the Series 9. How does that seem for you in retrospect?
Congratulations Andrews, I am also a big JRDG fan and have owned many of their old versions - and what you are describing is precisely the Rowland "house-sound" (Guido will surely second me here). I think you need at least another week or two to go regarding the break-in period in order to start building your final impressions on the amps. I agree with DaveyF, these are one of the best amps around for sure!
After a brief conversation with Jeff yesterday I was able to dim the front panel LEDs using an internal switch. It made a huge difference, but I may end up turning them off completely.
I've continued playing music through them 24/7 and they continue to open up. Last night I re-played a couple of the discs from my first session and the improvements are striking. Bass response has filled in significantly and now matches what I remember having with the Boulder 2060. Highs have become slightly more extended and are smoothing out nicely. Detail retrieval remains some of the best I've heard both in the quantity and quality of information conveyed.
As I try different music I'm starting to notice some differences between the 925s and the amps that preceded them. Last night I played "Know What I Mean" by Cannonball Adderly and Bill Evans. With the Boulder and, to a lesser extent, the Levinsons Adderly's sax was very prominent with a huge amount of energy behind it which gave the impression of him being pushed into the room. This was always a very entertaining effect and always made this a pleasurable recording to play. With the 925s the sax is much more reserved and more balanced with the other performers. At first I was disappointed with this, but after listening to a couple of tracks I realized that I was getting so much more musical enjoyment from what I was hearing. The sax had weight and body with great texture and I ended up with a much better appreciation of the interplay between Adderly and Evans. I ended up listening to the entire disc twice!
The Boulder seemed to launch the musicians into the room with a great sense of realism. The 925s opened a view into the studio so that the entire event could be appreciated.
The last recording I played was the Reiner/CSO Scheherazade which is a perennial favorite of mine. I've always found the last movement to be a torture test for a system due to its mix of frequency content, dynamic swings, and overall energy. The 925s delivered a jaw-dropping reproduction of it and one of the most eye-opening listening experiences I've ever had. All of the typical audiophile stuff (soundstaging, imaging, etc) became irrelevant and I became completely immersed in the music. Instead of trying to translate what I was hearing into an orchestra playing in front of me I was able to immerse myself in the mental image and story that the artists were trying to convey. When the track finished I was both exhilarated and worn out.
As I was reflecting on what I experienced I realized that with a live performance I'm focused on the musical event and the emotional connection that brings with it. I'm not concerned with any of the technical details that we audiophiles tend to get mired in. With the 925s I'm finding that my system is allowing me to focus more (if not solely) on the musical event and experience without feeling compelled to worry about the performance of the stereo itself (or whether or not the violins are far enough to the left). I may be stumbling onto my own personal definition of the absolute sound.
Sounds like 2 months even if you go 24/7?
Yeah, although I'm guessing that they'll be mostly cooked after about 500 hours. Apparently the input transformers take the most time to run in and with those I can play signal through them with the amps off. I'll probably wait a few weeks and then start running a burn in cd at full volume with the amps off. Corus takes even longer to finish so this will be good for both.
