Were y'all here in '97? We got about 57"... Do NOT expect anything like that this year! I hope we get snow this week, as then we usually get a break for a couple of weeks. End of October is usually cold.
Think outside the box and beoynd the cone.
I've been a happy Sanders 10C owner for some time now. I run mine with dual Magtechs, one per side. The system sounds phenomenal to me.
Lately I've been wondering about passive crossovers instead of the Behringer. Has anyone tried this? Something about digitizing my analog front end just seems weird. . .![]()
I misdoubt you can achieve as good crossover performance using passive... You could go to a DEQx or similar, perhaps, or check out Bryston (active analog) or Marchand (active or passive analog) units.
In my estimation, the best performing crossover sonically is passive, but line-level. Signal level chokes don't have the linearity and loss issues that speaker level ones do, and NP0/C0G capacitors are about the most perfect money can buy but aren't available much above 100nF.
In the case of the Sanders Sound 10c I think they x-over around 150 hz. My Innersound Kaya's are an earlier design and are crossed at 350 hz forth order. At those frequencies is it possible to make a line level x-over with those parts? How hard is it to make a forth order one? I assume one would need two outputs from their preamp to pull off a 2way line level x-over?
