If any of you are in Asia, the event has been extended by another day - to Tues 20th Nov. I will be there setting-up on Sat 17th.
Gary, you must be super human, your travel and work schedule would kill me in a week.
Minimum footprint for setting-up is 600mm (W) x 450mm (D)
However, you need to add 430mm x 232mm for the power supply unit and 260mm x 230mm for the air condenser unit. This is the first vacuum table with a pump I couldn't hear, so no problem having the air unit on the rack.
Your wife wouldn't let you go anyway.
You're a mean man. Now I have to go back to cringing.
Carl-I'm still trying to figure out if your wife truly tells you what you can and can't do or if you use her as a buffer for things you don't really want to do like hang with us at RMAF.
When I was working, or we were both working, it was actually much easier to reserve time away. When I sold my business last year to "retire", whatever that means, we spend all of our time together now. I actually have to give her central planning gene an enormous amount of leeway to get away. She actually WANTS me around all the time for whatever entertainment value I provide. I WANT to make excursions without her necessarily being present i.e. backpacking, skiing etc.
Part of it is also I just enjoy being lazy and irresponsible for the past year. I will probably go back to work in some capacity in a year or two, but I am in no rush.
You are right, though, she is probably an excuse for my laziness as much as anything.
incredible table Gary, "the sky is the limit" applies perfectly here!![]()
Carl, you and you wife have my admiration. After 38 years together and you still want to spend all your time together. I hope that I can still say that 27 years from now![]()
You can work with your sister. You can stay married.
