I am pretty sure that 43.141592654... is the one and only frequency for you, Steve.![]()
Nyal
It seems counter-intuitive. I do however believe that running the mains full range AND adding subwoofers provide the smoothest response possible... I have seen the response in my own case getting better by adding a third subwoofer.. This system is not more nor am I able to retrieve the graphs ... I can however point to some other people who have performed similar experiences ... or to the papers of Floyd Toole and Sean Olive. I would have liked Earl Geddes to chime in since the protocol I used was his , a variation on the multi subwoofers from Olive and Toole for producing better bass response in a room ...
My point is anecdotal. I have gotten the best bass with speakers that could hit 25 Hz in my room with autority .. the addition of 3 subwoofers, one corner placed and not EQ, strangely produced the best bass I have had in my system, actually in most systems. Steve here use EQ'd Gotham to supplement his full range running X-2 and believe me both aurally and measurable his bass is excellent .. I actually believe he would have gotten even better results by using a higher crossover point; something that in I would found to be anathema to high End reproduction only a few years ago ... 43 Hz is Ok but higher might produce better results ..
it's not simply a matter of the bass absorption in the room ... more subs result in better bass, smoother , more extended more integrated ...
The trick become : Place the mains wherever they image best , then add subs to bring the bass smooth and integrated ...
I will PM Earl Geddes and see if he's willing to explain his method here ...he's done it somewhere in this forum but very succinctly ...
P.S. Steve please, leave your system alone .. It took you months to get to that level of bass integration .. Don't listen to me ... .... .... .... ...
....... but slightly higher(50?, 60?) ... might even be better![]()
My AVR and sub do have (independent) phase compensation, a topic I touched on elsewhere and agree is critical to matching sub and mains.
Of course one can try running subs over the full range speakers without a crossover (I think that is your point?). This may or may not produce good results, wheras the method of matching speaker roll of and low frequency extension point with the sub XO is pretty much always going to work, even when you are using a cheaper sub like a Velodyne DD model with Avalon or Wilson speakers.
I'm not Chuck, but the TacT will only manage 2 subs, unless they're slaved in some fashion. What I'm trying to sort out is, if Audyssey Sub flattens the response and then one uses a non-flat curve in the TacT (i.e. one with some LFtilt-up, as is common), the TacT is correcting the Audyssey corrections!
What say ye, Chuck?
