So now comes my dumb question as I am not versed in electrical matters but what does QW connote
We added the amperage of every single piece of eqipment we had in the studio, and doubled it.
Myles
It took three weeks for your hearing to accept the system new sound. That much I will grant you... I don't believe much in dedicated lines as the best solution, that I have made it abundantly clear in this forum and other we both frequented...
I find your experience rather unique: Most audiophiles who have gone to dedicated line report immediate improvement ..
My first reaction to my system with better AC.. when I moved (by necessity) to a Double conversion Telecoms grade UPS (which by the way survived the whole thing ) which provides much better AC than Anything from the commercial grid ... with a THD of less than 3% under 150% load and absolute voltage stability +or - .5 % deviation from 120 V at full load and capable of delivering 15 KW continuously not KVA .. Kilowatts .. completely isolated from the EMI, RFI the commercial grid from any country has to be subjected to ... The first thing I knew immediately was that my system was much different. Bright? No. Unlistenable ? Absolutely not ...
I am sure it takes a while to accept certain things, including better system, so used and even addicted we often are with some of our systems faults.
he is a price list. scroll down to Model Q. mine is the 10WQ. then i added OFC copper and three filtered circuts for my digital player and digital amps on my bass drivers of my speakers.
if you figure how much power conditioners can cost; and the fact that likely every component just got upgraded....it is cheaper than many upgrades that are less effective. and it improves every piece of gear you will ever buy.
Thanks for the pointer; I found it about 10 mins after posting...![]()
Are you saying that with one of those big boys power conditioners from the likes of Nordost, Audience, or Running Springs are no longer necessary? If so, then yeah, the cost is a bit easier to swallow. I really like the idea, though, and from comments I've read here I should add it to my "one day" wish list.
i trust you saw my correction post above...
I did, thanks. I'm looking even more forward to arranging a visit with you!
i just got back from a meeting with my contractor and electrician. we set an install date for next Wednesday and Thursday (if necessary).
i should have Steve Dobbins tt 'The Beat' before the end of September. when that arrives (or we know more exactly when it will arrive) we can set a date for your visit.
hi mike , as i posted on another blog, please let me know your first impressions...... & of course after the burn in. i know you will love the equi=tech.
gary
last night i unplugged/disconnected the whole system so the electricians could properly test the circuits during the installation today. so it's stone cold. i just listened for 20 minutes.
"Toto; we're not in Kansas any more."
