You should have a dedicated AC line. Do You? Are you using MIT power cords? What is the length of the IC between the preamp & the power amp? What length are the speaker cables? Regarding the MIT Magnum cables, I'm sorry to tell you that (a) they are VERY GOOD cables, (B) they are NOT recommended with Spectral equipment. One other question; Are you using any kind of power line conditioner. If so, what type?Hello,
I know the new speakers has a better resolution.
But ialso discovered that the ACpower supply has a large effect on this.
Every time i change somerhing on the AC site the sibilance is getting worse.
After some days it is less notable.
The Cdp is an AR CD 3
All cables are MIT magnum MA
