That would be tough considering the X-2s are manually time aligned when set up by the dealer. Unless of course the set up procedure was not followed to the letter.
Introduction • Epiphany in Vienna • The Drivers • The Crossover • Aspherical Propagation Delay • Specifications
Company Conversations with Dave Wilson
Authentic Excellence
Authentic Values
History
Events
News Current Newsletter
Newsletter Archives
Press
Reviews
Awards
Dealers U.S.
International
Contact
Pro Users Music Industry
Motion Pictures
Home
A musical waveform is a complex overlay of frequencies, amplitudes, and phase relationships. With current technology, no single transducer can reproduce the full range of music at realistic sound pressure levels and maintain consistent dispersion. The only practical solution to this problem is a multiple driver array, but multiple drivers introduce their own set of problems, chief among them the challenge of preserving the precise time relationships of the musical waveform. The fact is, misalignment of the drivers by small fractions of an inch will audibly degrade transient performance, soundstage height, width, and depth, as well as introduce tonal anomalies that destroy the otherwise convincing "presence" of an instrument or a singer's voice.
The key to solving this problem lies in the vertical alignment of the various drivers in an adjustable modular array so that each driver's waveform propagation "matches up" with its neighbors' in such a way as to create the sonic equivalent of a single point source.
Wilson's patented Adjustable Propagation Delay has long set the standard for precise driver positioning in order to ensure correct propagation alignment for a wide range of listening locations. Alexandria took this technology a step further with the introduction of Aspherical Propagation Delay. Not only can each driver module move forward and back in the time domain, but each module rotates on its polar axis to achieve optimal dispersion for any chosen listening postion.
In conventional systems, drivers are mounted in a flat baffle such that each driver is positioned at a different distance in relation to the listener. Thus, energy from the tweeter arrives at the listening position in advance of the midrange, which in turn arrives before bass generated by the woofer. The problem of achieving both time-domain coherence and optimal driver dispersion is only exacerbated by larger speaker systems. Most speaker designers simply ignore this measurement.
With Aspherical Propagation Delay. Alexandria's driver modules adjust to achieve optimal driver dispersion for nearly any size room and for any chosen listening position. The Alexandria and now the MAXX Series 3 are the only loudspeakers to utilize these combined innovations.
In many Stereophile speaker measurement sections it's noted where drivers are wired in inverted polarity vs. others in the same box -- this presumably to smooth frequency response and perhaps compensate for the phase shift inherent in steeper slopes.
A while back somebody got a hold of a pair of speakers on the west coast which was used in a favorable review. The new owner never got them to sound right and gave up. In frustration he sold them on-line and shipped them to Japan. The owner in Japan also was disappointed and took them into a shop to see what was wrong. The shop discovered that the drivers had been wired out of phase, reversed/corrected the connections and all was good after that (from what I know).
Now I wonder about what I thought I knew after reading rblnr's quote.![]()
Some reading about crossovers, and there is a bit about wiring out of phase toward the bottom:
http://www.aperionaudio.com/AperionU/crossover.aspx
Simply wiring the tweeter “backward” (with amp positive to tweeter negative) can correct this problem. But, if the phase differences tuned out to be, say, 90°, then there would always be some cancellation and the driver outputs would need to be increased in the crossover zone to compensate.
Thiel, ATC, Cabasse, BG and some others in addition to KEF go the coaxial route. And the argument is that it's more of a point source, and better time wise as the voice coils are aligned. The cone around the high frequency driver can act as a waveguide.
A reason it's not so common is that it usually means building your own drivers which most manufacturers don't do.
some info from Thiel:
http://www.thielaudio.com/THIEL_Site05/Pages/FAQs/faqtimephase.html
Coaxial
Many companies - from those producing small cheap car-speakers and spekers for TVs make CoAx units. In theory it is quite simple - just use the center for some kind of HF driver and you have a "two in one" speaker. Cabasse has gone a step further and made a "three in one" speaker.
Shown here is Transmission Audio's 6,5" woofer with the new Clip-on ribbon attached inside the woofer, thereby saving space.
... provided there's no crossover in the design!A time-aligned speaker will be phase coherent by definition.
