Hi
The 20.1 Maggies are amongst the best speakers I have heard.. Myles is right they require serious amp and in my opinion stout SS make them sing. The thing is that they are very inefficient
OMG twice in a row...this is getting to be a habit
Hi
RUR,
Thanks for doing the research. Here's a hint of what I am talking about from the blog:
"........ In the mid-to-low bass the CLX is a little like one of those coloring books that restaurants used to give away; you get the outlines of notes with utter clarity, but the shapes could use a little filling in."
By the way, you have an amazing system! And no your system does not sound thin thanks to the excellent Mac gear. On the other hand, if you plugged in a Quad or an SL in your system, it would sound more fleshed out, IMO.
I will look for the reviews later today as I have to crank something our at work. However, if you go to the avguide.com site and scroll down to "buyer guides", the loudspeaker guide has the CLX and Quad reviews back to back.
OMG twice in a row...this is getting to be a habit![]()
The system was driven by Atma-sphere, which is as good as it gets in tube amplification. It definitely puts "meat on the bones".
Atma-sphere, OTL's and amps like the Messa Barron are not supposed to be good matches with impedance dropping electrostatics.
As much as I love and respect Atma-sphere amps, from what I've read and been told they are the worst sort of amp to match up with Martin Logans.
Your "thinness" in this case was the amp in my opinion.
I have no idea why or how the Soundlabs got around this.
There was this thread over at the ML forum on this very topic a while back too:
http://www.martinloganowners.com/~tdacquis/forum/showthread.php?t=3969
I spoke to Ralph in the past, maybe a bit over two years ago, concerning a pair if MA1 MK2's for sale in my area. He suggested that although the amplifiers would be a good match for my reQuests, their nominal impedance was a bit on the low side to keep an OTL amp happy. The solution was a pair of "Zero" matching transformers (or autoformer as often called) which would raise the speakers impedance for best performance. Odd that you would need a to purchase transformers for use with an output transformer LESS amp, but thats how the conversation went. Do a goog on zero autoformers to dig up more info.
Tj
From the link:
I would love to hear an OTL (like a GRAAF), Messa Barron or Atma-Sphere amp (of any design) with Martin Logans and form my own opinion, and not rely on that of a reviewer.
I mentioned the Messa Barron because it got a mixed review when it first came out (17 years ago?). I focused on the positive part and the lovely industrial design and it has been on my wish list to hear for many years. The flaw as reported was the load dip, reportedly part of the design with no fix other than forgiving speakers.
I didn't mean to imply that it was. I read that the power characteristics shared some traits. Techinical stuff I'm not versed to repeat.George:
Don't think the Mesa amp is an OTL:
For the most part you have put forth an erronoeus theory to get Ralph to make an appearence.![]()
Myles IME with Ralph on Audiogon is that he usually makes an appearance either to correct someone or to expand on thier comment. Nothing you said was erroneous. Yes I was offered the option of the autoformers. Right or wrong I thought autoformers was just a fancy name for transformer. You can use the Atma sphere with low impedance speakers and not have it oscillate or blow up. However the impedance mismatch can cause frequency response problems.
The Coincicdent Victory I think is a 16 ohm box speaker that would go well with the Atma-sphere. I'm not suggesting you have tos find a 16 ohm speaker. Ralph himself would say at least eigth ohms.
BTW, that's why I always thought that Quad 63s sounded best (like they actually had more lows than it seemsed) with George's modded Futtermans OTLs, eg the speaker's impedance goes way up in the lower frequencies :
http://www.stereophile.com/floorloudspeakers/416/index11.html
BTW Myles where are we on the CJ amp breakin?
