Mass Loading!
Johnny Vinyl
May 16, 2010
8,570
61
38
Calgary, AB
I've been forever wanting to mass-load my speakers and have finally found a place whereby I can get the material (sand) to do so. I hear a lot of good things about the effects of mass-loading, but have never experienced the results myself. I've heard the bass really tightens up and that the soundstage and imaging even improves.
If I were to do this, should I expect those improvements?
Not sure, some questions:
Are your speakers designed to be sand-filled?
Do you have a floor standing speaker?
Yes..I have Totem Sttaf floorstanders and I beleive they can take about 20lbs of sand or so.
Doesn't hurt to try. I wouldn't use sand though. I would recommend something like No.9 birdshot. Just don't forget to wash your hands thoroughly afterwards.
They made big differences with the VR-2 and VR-4jrs which were designed to be loaded with shot.
Some people prefer sand, some people prefer lead and the hard core aficionados will mix them, claiming they mutually damp their resonances. The exact proportion of each and the caliber seems to be also critical. ;)
I have owned some speaker stands that could be mass loaded. Curiously the amount of sand was very critical - if completely filled the bass frequencies would seem to loose slam.
I have no problems with the effects of sand on sound but have issues about sand's propensity for moisture. moisture and wood, not good. :(
Where would someone find No.9 Birdshot? I don't think I've ever seen a gunshop in Canada, which is where I suppose you'd find that.
Al Simmons Gun Shop
122 Locke St S, Hamilton, ON L8P 4A8
1-877-454-0416
Worth a shot to call.
Good one Jack! A guy from the PI telling someone from Canada where their local gun shop is! Priceless. Not to mention your pun...:D
Al Simmons Gun Shop
1-877-454-0416
Thanks Jack! Kudos on the quip....funny!:D
:D
