i have one. it's like Mikey says; cleans great, easy to use.
i also have a Loricraft PRC4 Dlx which allows for use of a 3 step chemical process. i use the Audio Desk about 80-90% of the time.
this morning i cleaned 12 Lps (both sides) while i listened, in about 90 minutes. i have it in the hallway outside my room, and i leave the door adjar. when the cycle ends there is a short buzz and i go out and remove it. then i put another Lp on and go back to listening.
you do need to 'touch up' some Lps with a few drops of water. but that is very quick. the fact it blow drys instead of vaccuming means no static build up to attract dirt.
i've had mine for over 2 years. i did have a motor fail on mine when it was just out of warranty; they gave me a no cost exchange to a refurbed one.
the perfect companion to your X-2's.
