Cinema processors that manage multiple subs
Kingrex
5,352
4,091
715
I have a friend building a home theatre. My understanding is Subs are the hardest part of any installation. He is looking at a Marantz Amp 20 and AV20. I was advocating more than 1 sub to get even distribution of bass in the room. The room is probably 18 feet deep and 25 feet wide. Is there a processor that handles multiple subs and has a built in measuring system that will integrate multiple subs into the space. He has one Def Tech sub already. He is open to others.
Suggestions on a processor and subs to integrate into the system.
Consider front left/right speakers with built-in powered subs and configure them for full range.
Then add the subwoofer on the LFE channel. The sub can be placed on the side or towards the rear of the room.
Can be more cost effective than multiple subs.
Some subs will calibrate themselves, then just need to set the volume level in the processor.
Several processors handle multiple subs, but they are way more $$$ than the Marantz. The above suggestion works with one sub output.
Isn't 1 sub prone to the same issues as a 2 channel system. There will be a sweet spot for bass. And other seats may be, not so good. Won't more than 1 sub give even response in the room.
the best dsp approach can set up a room for a single seat or multiple seats. and include the subwoofers. depends on your expectations.
I was proposing 3 subs. Two built into front left and right channels that get front channel bass signal. The one subwoofer gets the .1 LFE signal. There is some overlap when the crossovers are set with this in mind.
I use one subwoofer in the front corner and two of the side rear speakers have built in subs and are configured for full range. Works great.
One would have to try it and play with the sub position and tuning.
By the way
By the way, the AV20 handles 4 subwoofer channels. Just need to choose another sub, which depends on budget and space constraints.
Speakers are already in the walls and ceiling. Paradigm. If the AV20 handles 4, do you think it will room correct all 4 for even response at multiple locations.
Would be great to know what speakers and speakers layout he have.
First suggestions is AVM90 - reasonable price/performance, but it is more expensive then AV20.
AVM90 have better audio section, but it lacks streaming - specifications say it is Roon Ready, but it is only with AirPlay.
For streaming you need external streamer connected with digital cable - coax or optical - extra expencies if it is systrem for HC and Stereo.
AVM90 review on Audioholics:
The key here is the measurement/DSP/EQ system and, currently, the most advanced consumer system is DiracLive-ART (Active Room Treatment) which can handle effectively multiple subs. DL-ART is available on Maranz AV10 and on Storm Audio devices. More coming from Hyperion (https://www.hyperionprofessional.com/processors) and others.
Reactions: rob
I would throw Lyngdorf into the mix for sure.
Great heritage.
Vast world wide dealer base.
Build quality (tank) among the best.
Room Perfect DSP.
IMO, Sound is excellent, both 2 channel and all multichannel formats.
Great app for navigating.
Downside is on entry model (MP-40) there are no analog inputs!
Great heritage.
Room Perfect DSP.
Not sure how it handles multiples subs for DSP. Individually or in aggregate but it is not capable of utilizing the multiple subs (or other speakers) to support each others corrections. Same can be said for the otherwise admirable Anthem devices.
Kal is correct. Dirac Live ART is a very powerful tool that can yield excellent results.
Having someone who is experienced and able to extract the most from the software is important.
The higher end Denon AVR’’s have 4 sub outs, and I’m pretty sure they can also handle Dirac Live ART now.
Even Audysey can do a decent job once you lift the sub level a few DB.
The Trinnov processors are excellent and feature ‘Waveforming” (DBA) with front and rear subs which is superb.
Another option is to use MiniDSP 2x4HD or FLEX HTX to manage the bass, though this requires quite a bit of work with REW, measurements and creating an in room response.
2 channel is less a priority. More background music. Cinema is the priority.
$15k is max budget.
I think he said its 7.1 now. Adding 2 subs would be 9.1.
Any processor should accept bluetooth or wifi to control streaming content via a phone or tablet. He does not want to pay for Roon to stream.
I am assuming every processor has multiple zones. One for upstairs music (background, not hifi) and the second for movies in the main room.
Hi Kal,
I think that if someone is looking to achieve the flattest frequency and most time aligned response and is willing to take the time to get there then Dirac is an excellent option.
Lyngdorf focuses primarily on the phase/time alignment aspects.
Room Perfects strength is in the bass domain.
If one is looking for an overall immersive listening experience (movies and music) I would not dismiss the Lyngdorf solely based on the things you mention.
That being said, Dirac can be implemented along with the Room Perfect but most prefer without the Dirac.
The only limitations of the Lyngdorf software is the person using it.
Can you give me (or provide a link to) information about the evolution of RoomPerfect? I last used it years ago and, while my experience with it was quite positive, my contextual references have evolved since then.
For surround sound without overheads, the convention is 7.3 indicating 3 subs and 7 channels.
9.1 would be 9 channels and one sub.
For Atmos 7.1.6 would be 7 on the floor, one sub, 6 overhead (my home configuration).
7.3.6 would be 7 on the floor, three subs, 6 overhead.
